www.ColoradoClassicBroncos.com http://www.coloradoclassicbroncos.com/ |
74 Baja Race Bronco - Baja or Bust http://www.coloradoclassicbroncos.com/viewtopic.php?f=3&t=9675 |
Page 9 of 11 |
Author: | ZOSO [ Fri May 03, 2019 11:15 am ] |
Post subject: | Re: 74 Baja Race Bronco - Baja or Bust |
Author: | casadejohnson [ Fri May 03, 2019 7:34 pm ] |
Getting our NORRA drink on Check us at on NORRA.com. Live streaming Sent from my iPhone using Tapatalk |
Author: | Moab Mike [ Fri May 03, 2019 9:15 pm ] |
That is awesome! Chris the carnage is only a testament to your actually driving it the way it was built and the way it was meant to be driven! I hope it doesn't hit your pocket book too hard. Great work from your pit crew too!!! What's that on Phil's tongue? |
Author: | landshark [ Thu May 09, 2019 9:44 am ] |
We pulled back into Denver yesterday evening from Cabo - I will post up a race report soon! Thanks for following along, has been surreal. |
Author: | Jesus_man [ Thu May 09, 2019 9:50 am ] |
Welcome home! Get settled back in, but don't take too long! We are chomping at the bit for the stories!! |
Author: | Jesus_man [ Fri May 10, 2019 8:01 am ] |
Meanwhile.... |
Author: | Digger [ Fri May 10, 2019 2:28 pm ] |
Author: | landshark [ Sat May 11, 2019 2:47 pm ] |
Clean up and tear down has begun. |
Author: | Digger [ Sat May 11, 2019 8:53 pm ] |
Wow. That cage really took a hit. |
Author: | Jesus_man [ Mon May 13, 2019 7:44 am ] |
Author: | Digger [ Mon May 13, 2019 8:53 am ] |
Interestingly, you hit it in about the strongest section of the cage. Did the cage move at all? It looks like it just collapsed the tubing. Nice work either way! |
Author: | landshark [ Mon May 13, 2019 10:47 am ] |
Author: | Jesus_man [ Mon May 13, 2019 12:21 pm ] |
Rumor was the radiator is what didn't allow you to get into La Paz. Not true? |
Author: | landshark [ Mon May 13, 2019 12:55 pm ] |
Author: | Dirtheadz [ Mon May 20, 2019 9:13 am ] |
I TOLD YOU.... "Careful, desert racing is addictive!!!!" Now your hooked, its worse than black tar heroin (being from Las Vegas, ask me how i know!!!! many nights, countless $$$$$$ and awesome memories) |
Author: | Viperwolf1 [ Fri May 31, 2019 10:54 am ] |
Here's a short video from the race. https://www.youtube.com/watch?v=C85wAkHN6To |
Author: | Rox Crusher [ Fri May 31, 2019 4:06 pm ] |
overtaking buggies at 100 mph looks fun |
Author: | landshark [ Thu Jun 06, 2019 1:39 pm ] |
Well, we pulled the engine a few weeks ago and it's out to the Engine shop for a tear down and check, ran it real hot and want to make sure it doesn't have any issues. Have most of the replacement pieces I need to fix the bent stuff. I will be replacing the front driver inner fender sheet metal and pulling out the corner core support and refitting new fenders and grill. Realized we almost lost the hood at some point and will add more re-enforcement to the hood pin retainers to make sure they dont' peel off like they were doing. Anyway, a little slow going as I had to work on the 69 as it needed some TLC and I daily drive it and I am prepping the 76 to sell as I just don't have time to give it the love it deserves :) Anyway here are a few more carnage pics for your entertainment. |
Author: | Eck [ Thu Jun 06, 2019 1:46 pm ] |
Only the last picture of an empty engine bay is showing up Chris-- I NEED to see the carnage!! |
Author: | landshark [ Thu Jun 06, 2019 1:53 pm ] |
more.... |
Author: | Jesus_man [ Thu Jun 06, 2019 2:27 pm ] |
Wow! So both front and rear tires nailed the rock breaking two wheels?? It looks as if someone dropped it off in that spot on it's side with a heli. |
Author: | landshark [ Fri Jun 21, 2019 8:41 pm ] |
For those that would like to snooze along - I posted all the 4k video we captured in the 2019 NORRA race from our 360 degree camera (Garmin VIRB 360). You should be able to look around in 360 glory in most browsers and mobile devices, looks best in 1080p or larger. The gauges on the dash were added later when the video was exported. The camera is pretty cool, captures great video and saves a ton of metrics. The software sucks. Enjoy! |
Author: | Strike2 [ Sun Jun 23, 2019 10:18 am ] |
Cool video ! In true Baja fashion you get a story before the race even happens. Good thing Mike trained at hi altitude or that “pre-run” jog in a race suite could have ended badly Thanks for sharing |
Author: | Jesus_man [ Sun Jun 23, 2019 2:51 pm ] |
What a cool way to document something! Thanks for sharing! |
Author: | landshark [ Sun Jul 21, 2019 3:03 pm ] |
Post subject: | 74 Baja Race Bronco - Baja or Bust |
Actually been working on the racer off and on the last few weeks. Made some progress. Cut off both radius arm mounts and welded some stock HD ones on. Went through the front axle and swapped knuckles, new hub bearings, new rotors and pads. Picked up some DOM and replaced the bent tie rod and drag link mount. Finished fixing the front body damage and welded everything in, started reinstalling stuff and prepping for the engine coming home. Mike came by last weekend and pushed out the rear quarter and took the fenders/grill for some body work and primer. More to be done on the rear but it’s Looking a bit better now. Before: After: I am moving to the rear axle next to look things over, will be replacing those rotors with the EBC cut and dimpled rotors as well. I picked up a new AFR gauge and will be installing to get our tuning nailed down. Will also be installing a fuel gauge before winter for the fuel cell, be nice to know how much we have left. Hope to have it running in the next few weeks and over to Jason for some cage repair! |
Author: | pgilbeau [ Sun Jul 21, 2019 6:21 pm ] |
Looks like your making some good progress on being ready for next year! |
Author: | landshark [ Mon Aug 12, 2019 12:01 pm ] |
Making some progress, engine is back and in, will finish up all the small stuff here soon and then off to cage repair and testing in September. IMG_8344.jpeg 4F74F08D-6C26-4CB4-A2C8-3B96A80A2FE7.jpg IMG_8355.jpeg |
Author: | Rox Crusher [ Mon Aug 12, 2019 12:15 pm ] |
did you have to do anything to the engine ? |
Author: | landshark [ Mon Aug 12, 2019 12:32 pm ] |
Author: | Strike2 [ Mon Aug 12, 2019 1:53 pm ] |
Page 9 of 11 | All times are UTC - 7 hours [ DST ] |
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group http://www.phpbb.com/ |
