Tire rack mounting on drivers side?
Postby Kinder » Wed Mar 11, 2015 7:02 pm
Yeah man, now you've got it!
Re: Tire rack mounting on drivers side?
Postby rooster » Wed Mar 11, 2015 7:19 pm
Ok sweet! What do you guys think of a bumper similar to a prerunner but with square tubing?
rooster
Postby Justin » Wed Mar 11, 2015 7:25 pm
Post a pic of what you're thinking about. The problem with square tubing is bending it.
Postby rooster » Thu Mar 12, 2015 5:58 am
Well I was thinking of something like ecks front bumper because I don't have a tube bender
rooster
Postby Justin » Thu Mar 12, 2015 7:51 am
Gotcha. Square tube is a fairly common solution if you're looking at a straight bumper. If you're interested, I'd be happy to build something for you.
Postby rooster » Thu Mar 12, 2015 8:42 am
That would be awesome Justin, but I love to fabricate and I've built several bumpers over the years for some of my friends.., nothing too fancy , but I like the idea of making it my own, ya know. If I had a tube bender I would just make them out of round 2" or something
rooster
Postby Justin » Thu Mar 12, 2015 2:11 pm
We've got a bunch of benders in the club-post up what you're thinking and someone may be able to knock it out for you. I've got 1.5" and 1.75" dies for mine.
Postby landshark » Thu Mar 12, 2015 2:12 pm
Postby Justin » Thu Mar 12, 2015 2:20 pm
I almost spit water all over my keyboard.
Postby rooster » Thu Mar 12, 2015 4:24 pm
Tank you guys for all the help, time to start drawing plans!
rooster
Postby rooster » Thu Mar 12, 2015 6:21 pm
Does anyone know where I can find steel at a good price?
rooster
Postby Eck » Thu Mar 12, 2015 6:30 pm
I've found DenCol is fair.
Postby Kinder » Thu Mar 12, 2015 6:43 pm
I'm a fan of Hinton.
Postby Justin » Thu Mar 12, 2015 7:09 pm
Both are good. Dencol has a better scrap bin. If you don't need a specific size c&m has a great scrap yard. Altitude is a little more expensive, but has Saturday hours. Man, I buy too much steel.
Postby rooster » Fri Mar 13, 2015 6:05 am
Ok guys I've decided on a design for the front and the back will be just a 5x2 1/4" steel tube with tire rack on drivers side, what do you guys think? Also is there anyone that is willing and able to bend a couple pieces of 2" pipe?
rooster
Postby sykanr0ng » Fri Mar 13, 2015 1:24 pm
rooster wrote:Ok guys I've decided on a design for the front and the back will be just a 5x2 1/4" steel tube with tire rack on drivers side, what do you guys think? Also is there anyone that is willing and able to bend a couple pieces of 2" pipe?
Do you have a bigger picture of the black one with the roof rack?
I'm looking for ideas.
sykanr0ng
Postby rooster » Fri Mar 13, 2015 1:52 pm
They are the same
rooster
Postby sykanr0ng » Fri Mar 13, 2015 5:00 pm
rooster wrote:They are the same
The roof rack is not visible in the second pic.
Maybe I should have been more specific.
sykanr0ng
Postby rooster » Sun Mar 15, 2015 5:04 pm
Sorry I don't have anymore like that, have any of you heard about using a trailer spindle for a tire rack pivot?
rooster
Postby Eck » Sun Mar 15, 2015 5:10 pm
rooster wrote:Sorry I don't have anymore like that, have any of you heard about using a trailer spindle for a tire rack pivot?
Yep- that's pretty much what they are.
Postby ZOSO » Sun Mar 15, 2015 5:40 pm
Another thing I have seen is guy's use and spindle, hub and outta shaft. Use the lockout to hold it in position while open. Then you will have a place to hold a spare hub.
Postby Gunnibronco » Sun Mar 15, 2015 6:20 pm
On another forum, I saw someone use a hub, spindle, lock out, etc to bolt up their spare.
Postby DanHall » Sun Mar 15, 2015 7:32 pm
I used some spare 1.5" DOM, 1/4" wall, for the pivot on my carrier with a 1" grade 8 bolt down the center. Mounted in double shear it shouldn't go anywhere. I had enough tube left over after redoing the tie rods and going with 1 ton ends so that part was free. The main portion of the rear bumper is 2x5, 3/16", steel since I had to buy a full stick when I did the rockers. I'll go grab a pic if you're interested.
I think the main reason most are mounted on the passenger side is that if you're pulled over on the side of the road you can open without it swinging into traffic.
DanHall
Postby rooster » Sun Mar 15, 2015 9:22 pm
Good info guys, and yeah if you could get a
rooster
Postby rooster » Sun Mar 15, 2015 9:24 pm
Pick of how you mounted it that would be awesome! And that is a good point about it swinging that way
rooster
Postby DanHall » Tue Mar 17, 2015 4:07 pm
Here ya go. The DOM is in three sections to form the hinge. It is built with 3/16" thick material so it isn't light but it doesn't rattle around.
DanHall
Postby rooster » Tue Mar 17, 2015 8:18 pm
That's really cool, what size bolt is that if you recall
rooster
Postby sykanr0ng » Wed Mar 18, 2015 1:00 am
Now all I need to do is design the rest of my back bumper around that hinge.
sykanr0ng
Postby DanHall » Wed Mar 18, 2015 5:28 am
rooster wrote:That's really cool, what size bolt is that if you recall
1" Grade 8. I don't remember the length but probably about 6" since the bumper is made out of 2x5.
DanHall
Postby Gregg » Sat Aug 15, 2015 6:53 am
BNC04 wrote:Mine is on the drivers side. Justin and Kirk did the fab and paint, I did the design and cheering:)
You can see the section of 2 inch receiver hitch that is added to the plate for the tire. My plan is to build a license plate bracket and integrate a mount for a LED light for a backup, rear flood light. Right now, I have the plate zip tied to the rim of the spare tire. The license plate can move from the bumper receiver to the receiver in the tire carrier as needed.
Brett
Hey man. I'm headed off to the Breakfast in Johnstown and I was wondering if you're going and if you have your old rear licsense plate bracket?
Cool.
Shawn
Gregg
