www.ColoradoClassicBroncos.com - View topic - HELP!!
It is currently Sat Apr 20, 2024 6:19 am
Reply to topic  [ 15 posts ]
 HELP!!
Post HELP!!
I have a 73 bronco c4 auto 302 with under 2k miles. Yesturday it ran fine. Last night and today it cranks over 3xs the stop engine, now it just froze and no turn over. What could it be? Stuck in driveway!
Mon Jun 18, 2012 7:07 pm
Profile YIM
Post Re: HELP!!
Try and turn the motor by hang. Put a ratchet on the balancer bolt and make sure the engine turns. If it does replace the starter.
Mon Jun 18, 2012 7:30 pm
Post Re: HELP!!
Thanks ZOSO!
Thats got to be it. It turns but will have to wait til Tuesday to install since my son wants to help and he's in bed.
Mon Jun 18, 2012 9:12 pm
Profile YIM
Post Re: HELP!!
It turns, but I replaced the starter but still no turn over, battery good.
Sat Jun 30, 2012 12:46 pm
Profile YIM
Post HELP!!
Check the cables for corrosion, make sure all your grounds are good, clean, and tight, same with the battery terminals, does it click or make any noise when you crank it?
Sat Jun 30, 2012 1:00 pm
Post Re: HELP!!
I would also try jumping the starter solenoid and see if that is the issue.
If you need a hand I am off 287 and Niwot and would be happy to help.
66 1/2 Cab Rock Toy
68 Mall Crawler (someday)
Mon Jul 02, 2012 8:06 am
Post Re: HELP!!
Check the neutral safety switch.
Mon Jul 02, 2012 8:22 am
Post Re: HELP!!
It clicks when I turn the key. I will check everything today when I get home.
Sat Jul 07, 2012 9:50 am
Profile YIM
Post Re: HELP!!
Cables with visible corrosion are bad. Cables that are swollen and stiff near the ends are bad. That includes all the cables between the battery, starter and block.
Sat Jul 07, 2012 12:52 pm
Post Re: HELP!!
So, I finally got back to this bronco, I changed the coil, starter, solenoid and all the cables. I get a click when I turn the key. Still can't get it to crank. The block turned but that's it. Anyone have any ideas.
Sat Jan 18, 2014 5:29 pm
Profile YIM
Post Re: HELP!!
I would try giving the terminals a good cleaning with those brush things can't remember the name. Check the grounds after that.
After that check and see if the starter is getting power to rule that out even if it is new. Then start working your way back.
Sat Jan 18, 2014 7:25 pm
Post Re: HELP!!
X2 on battery connections.
If you have a volt meter you can measure the voltage of the battery. Anything less than 12.50 VDC is suspect and I would have the battery load tested at your local auto parts store. If you have 12.50 VDC or more at the battery terminals look for a bad/dirty connection.
Sat Jan 18, 2014 7:41 pm
Post Re: HELP!!
To rule out the battery & starter make a direct connection. If it turns over then start checking connections & components at either end of the system.
Sat Jan 18, 2014 9:17 pm
Post Re: HELP!!
Battery may now be dead after sitting for 6 months.
Sat Jan 18, 2014 10:01 pm
Post Re: HELP!!
I've got a spare starter I know works. In fact, it was the one I put in when my old one died at your house. I'm available off and on on Monday. I've can bring my multimeter but no battery charger.
Sun Jan 19, 2014 11:28 am
27,583,353 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
