rooster wrote:Ya so far I don't see any negatives as to mounting it on the drivers side
rooster wrote:Eck I really like your square tube bumpers, what did you do to make the hinge for your tire carrier?
rooster wrote:Thanks! That should be just what I need. What size square tubing did you use on yours?
Jesus_man wrote:I think the critical thing when building these is to keep them from bouncing. Metal fatigue causes the shank to shear off and now you'd got 100+lbs of tire and steel bouncing down the highway...
I used Delrin plastic to carry the weight when it's closed.
landshark wrote:Ah ya, forgot about that nugget.. you could mount it somehow to the center of the tire i guess..
which brings up another question. why does the license plate holder flip up? My guess was if you had to drive with teh tailgate down you could flip up the license plate and have it showing when the gate was down.
landshark wrote:Depending on where you live I would check local fabricators they usually have the parts precut and save you on shipping.
rooster wrote:Bnco4. That looks bada**. Thanks for the pictures! What size tubing is that?
kinder wrote:I thought the 2x5 was 3/16, I'm too old to remember. I think i matched the thickness what ever it was.
