Justin wrote:Depends how you mount it. That sounds like a good thing to whack your head on. I'm planning to put mine on the roll bar behind the driver's seat.
akaFrankCastle wrote:I'm running a similar set up to JD, but one in each upright. Both are cheapos from the parts store. Both can literally be torn out of the plastic keepers if needed.
Last year in Denver, while participating in a class, we brought in the oldest extinguishers we could find and tested them. Many of those brought in were 20+ years old. One was probably made in the very early 70's according to the markings on it. Everyone that we tested worked without a problem. The 70's model had been stored in an elderly man's pick up since the day he bought it.
Justin wrote:Gotcha, that works. What mount is that? I like it.
Dukietown wrote:I'd read that having them mounted vertically was a bad idea because the powder inside will get packed down into the bottom and not discharge when used. Sounds like that wasn't the case for you.
mickphatmac wrote:Have you ever gone into a building and seen a fire extinguisher lying flat on it's side???
