best hydroboost?
best hydroboost?
Postby trei75bronco » Tue Jul 28, 2015 5:53 pm
Ok I want hydroboost which is better ford super duty or astro why and how come. I have hoses and a bracket from my booster and a camper special mc. I can't stop the pig with 40s and I need too
trei75bronco
Re: best hydroboost?
Postby Gunnibronco » Tue Jul 28, 2015 7:28 pm
The hydroboost units are all fairly similar. The orientation of the inlets & outlets, master cylinder mounting brackets, reservoir, etc are what vary between them. I can't say one is better, you just need it all to work together, and fit under the hood. I used a 99 Mustang h-boost & the matching master cylinder, a very easy swap.
Sorry, I don't know which h-boost would fit your master.
Postby DanHall » Tue Jul 28, 2015 8:14 pm
I was running a astro booster and mc with no special bracket. Just modified the astro mounting plate and ran it straight out. That mc is pretty tall but it fit under my fiberglass hood. That was with the 302. I will have to see what fits when I get the explorer 5.0 in.
I haven't run any others but it stops my 35s with plenty of power to spare.
DanHall
Postby sbolt19 » Fri Aug 07, 2015 3:14 pm
viewtopic.php?f=32&t=4700
My hydroboost install walk-thru with pics using the astro van booster & MC
sbolt19
