Show me some better air cleaners
Postby Unaweep » Mon Sep 14, 2015 10:18 am
Hi, my Bronco has the inner fenders cut away which leads to lots of dust under the hood. While I will eventually install new inner fenders, can someone show me a better way to filter the dust and perhaps a snorkel or some way to bring fresh air to the carburetor?
It a 351W without a body lift and a fiberglass hood if that helps...
Erik
Unaweep
Re: Show me some better air cleaners
Postby TOOLMAN » Mon Sep 14, 2015 11:37 am
http://www.knfilters.com/airforcewraps.htm
Maybe something like this might be most cost effective...
TOOLMAN
Postby Gunnibronco » Mon Sep 14, 2015 11:39 am
I was going to say look for an AFR Brute Force filter & prefilter/wrap. The ARF is a cleanable dry element filter.
Postby Dirtheadz » Mon Sep 14, 2015 3:58 pm
Casadejohnson did a snorkel for Moab:
Dirtheadz
Postby Jesus_man » Tue Sep 15, 2015 12:04 am
Prefilters are a good idea for any rig, but especially yours.
Chad - I think you mean AEM?? AEM Dry-flow is a cleanable filter, but most important is it is oil-less. Whatever you do, don't get an oiled filter.
Or, just keep a fresh stock of paper filters and change them with the oil??
Postby Gunnibronco » Tue Sep 15, 2015 6:13 am
Jesus_man wrote:Chad - I think you mean AEM?? AEM Dry-flow is a cleanable filter, but most important is it is oil-less. Whatever you do, don't get an oiled filter.
Yes you are right. AFR makes heads. Alphabet soup.
Postby Unaweep » Tue Sep 15, 2015 9:41 am
The snorkel looks the easiest as I have all the dive gear already..
Is there a snorkel out there...most I see are for fuel injected?
Erik
Unaweep
Postby landshark » Tue Sep 15, 2015 10:33 am
You could build a cowl induction intake. Not sure which fiberglass hood you have but I plan
On sealing the air intake off and pull all my air in at the base of the windshield through the cowl induction hood.
I have all the pieces but missing time.
Postby Unaweep » Wed Sep 16, 2015 2:01 pm
That's a good idea but I haven't changed the oil yet...ever....so that's out.
Erik
Unaweep
Users browsing this forum: Google [Bot] and 5 guests
