Engine won't start
Engine won't start
Postby BillsFan76 » Mon Sep 21, 2015 7:00 pm
Sad day when 4 threads out of like 15 belong to the same person but here I am again :)
Finished putting in my rear driveshaft U-joint and drove up to O'Reillys. Drive home and everything started no problem. Went to start it again in my driveway and it wouldn't turn over at all, weird sound but nothing else. Tried a few times with no luck, ended up putting a trickle charger on in case battery was weak. A few hours later I gave it another shot and nothing, but when I looked under the hood, I saw smoke coming from the positive cable off the battery where it connected to this ( picture below). Not sure what this part is, forgive me if it's obvious. The positI've battery wire was so hot it actually melted where it connected to whatever the piece is. Not sure what caused it, it started and ran fine till this happened. What is the part where the positive wire connects? One picture is the part it connected to and the other is the melted positive battery cable.
1969 Bronco Sport-302-3 Speed Hurst on the Floor-Dana 20 TCase
Dana 30 Front-9" Posi Rear w/ 4:11's
32"s-No Lift
BillsFan76
Re: Engine won't start
Postby Eck » Mon Sep 21, 2015 7:09 pm
That's your starter solenoid. Could be bad...
Postby Moab Mike » Mon Sep 21, 2015 7:37 pm
Like Eck said your solenoid is bad. From the pictures it looks like you had a loose connection internally. That's common in that style solenoid. It doesn't look like the cable end was damaged so just replace the solenoid. Probably around $15 to $20 from your local parts store.
Moab Mike
Postby BillsFan76 » Mon Sep 21, 2015 7:58 pm
Thanks guys, one more trip to O'Reillys =)
32"s-No Lift
BillsFan76
Postby akaFrankCastle » Mon Sep 21, 2015 8:10 pm
Buy two. Put one in your Bronco toolbox. Seriously.
Postby hockeydad4-22 » Tue Sep 22, 2015 6:51 am
akaFrankCastle wrote:Buy two. Put one in your Bronco toolbox. Seriously.
Yes, what he said - trust me. You will never regret having the spare in your tool kit (the one you keep in your bronco at all times). Even if you don't end up needing it first, sooner or later, someone you are with will.
Postby colby45 » Tue Sep 22, 2015 7:02 am
+2 on this. So nice to have some spare parts handy if you need them.
Sally
'66 Halfcab
colby45
Images: 2
Engine won't start
Postby akaFrankCastle » Tue Sep 22, 2015 7:04 am
colby45 wrote:
+2 on this. So nice to have some spare parts handy WHEN you need them.
Fixed it for you.
Postby colby45 » Tue Sep 22, 2015 8:24 am
Fixed it for you.
Very good point! It's never a matter of if but when!
Sally
'66 Halfcab
colby45
Images: 2
Postby BillsFan76 » Sat Sep 26, 2015 6:15 pm
So I bought another starter solenoid, put it in, and when I hooked up the positive wire back to the battery it arced. Checked to make sure it was hooked up right and tried again and another arc. Disconnected everything and pulled out the solenoid and the connection for the positive wire was loose. Swap it out at O'Reilly's and put new one in and it won't start.
I've checked everything multiple times to make sure it's hooked up tight and still nothing. I have a few pics of the solenoid hooked up and the wiring around it. Can someone take a quick look and see if maybe I swapped something? Only one I wasn't sure of was a wire coming from the negative battery terminal grounded to the bolt where the solenoid is connected to the body. Went back and looked at a pic I posted here before and it seems to be Connected at the right spot.
Tried uploading a short video so you can hear the sound it makes when I turn the key but it never attaches the file. Can short videos be uploaded? Could I have ruined the starter itself with that arc? It was quick but I know anything with electricity can ruin things. Long post, thanks for the help.
Alex
32"s-No Lift
BillsFan76
Postby akaFrankCastle » Sat Sep 26, 2015 8:07 pm
Looks right.
Disconnect the ignition switch behind the dash, hook everything up at the solenoid, and see if you still have power on the large post on the right. If I'm reading everything correct, and I may not have, I think you might have a bad ignition switch.
Where are your grounds? Where does the large negative cable from the battery run to? Engine block? Frame? Anything grounding the engine to the body or frame?
Just spitballing here.
Postby Viperwolf1 » Sat Sep 26, 2015 11:14 pm
It's very possible that the damage to the original solenoid was caused by a shorted starter. You might want to have that checked out.
Postby BillsFan76 » Mon Sep 28, 2015 6:52 pm
I checked the wire setup from the previous posted picture to verify it was all hooked back up right and it seemed to be. After leaving it on a trickle charger two days I checked the voltage of the battery and it was perfect. Turned my headlights on to see how they did when starting it and my headlights died instantly. Decided to run to wal-mart and grab a new battery just in case and after putting it in, it started up instantly. The date on the battery was summer 2007, 8 years not bad.
32"s-No Lift
BillsFan76
Postby Kinder » Mon Sep 28, 2015 8:00 pm
That's a win!
Postby Justin » Mon Sep 28, 2015 8:51 pm
Congrats! That had to feel good.
