Auxiliary filler hose part number
Postby akaFrankCastle » Sat Nov 07, 2015 2:03 pm
Anyone have a part number for a fuel rated hose that works for the auxiliary tank filler neck?
Re: Auxiliary filler hose part number
Postby DLB » Sat Nov 07, 2015 5:58 pm
I was unable to locate that particular item as well - ended up with 2-90's coupled together
DLB
Postby Unaweep » Sun Nov 15, 2015 8:22 pm
I just went down to NAPA and found one with a similar bend (almost). That hose was longer but I trimmed it. It fits almost perfect, no problems when filling the tank. Cost was $21.
J.E.
Unaweep
Postby Kinder » Tue Nov 17, 2015 6:34 am
Can you pass along the part number for it.
Postby Unaweep » Tue Nov 17, 2015 11:35 am
kinder wrote:Can you pass along the part number for it.
I didn't save the invoice.
I just took the hose down and told the NAPA counter guy to match up as best he could a couple hoses that were similar in the bend radius and let me choose between the two.
J.E.
Unaweep
Postby Moab Mike » Mon Nov 23, 2015 9:02 pm
Moab Mike
Postby akaFrankCastle » Fri Dec 04, 2015 5:36 pm
Napa part number 1047. 2" fuel hose with 90* bend.
