It is currently Sun May 19, 2024 9:46 pm
[ 9 posts ] |
Stock Bronco nuts, bolts, and screws thread
Okay, there have been several threads over the years about what size bolts, what thread pitch, what length, etc. are needed for specific stock Bronco applications. I thought, "Hey, why not a sticky for all of those ankle biter type questions?". So, here it is. How about we keep it short, simple, and to the point. If you have a stock application, or common mod application, bolt, nut, or screw that you are trying to find, let's throw them up in here and see if we can't get a little single point of reference for all of those hardware questions everyone seems to have. Sound good?
Wed Jan 02, 2013 8:35 am |
Re: Stock Bronco nuts, bolts, and screws thread
This thread couldn't be more timely, Big O is a ground up build, every bolt and nut has been removed. I'll try and get a list going of what we've done so far, but may just jump in at the current build point.
Sun Jan 13, 2013 12:27 pm |
HIX
Joined: Tue Feb 15, 2011 12:38 pm Posts: 174 Location: Wheat Ridge Colorado
Tue Aug 13, 2013 9:24 pm |
What size and length screws hold the arm rests to the doors?
#14 shouldered hex head machine screw, 1" long.
Sat Feb 08, 2014 3:46 pm |
Constant voltage regulator to back of instrument cluster: 1/4
Mon May 05, 2014 7:47 pm |
Bellhousing to block: 5/8 Manual transmission intermediate adapter to 3 speed: 5/8 Manual transmission intermediate adapter to transfer case: 9/16 Cross member frame mounts to frame: 1/2 Cross member to cross member frame mounts: 3/4 bolt on top, 13/16 nut on the bottom
Sun Jun 08, 2014 12:27 am |
Looking for bolt and nut sizes for leaf spring bushing and hanger hardware. Swapping new springs into Stroppe'd and Old stuff is moving to Project X. Only have one set of hardware so I'm gonna run to the Depot.
Sun May 31, 2015 10:02 am |
Fri Feb 05, 2016 7:45 am |
D&D72
schweet!
Fri Feb 05, 2016 7:40 pm |
[ 9 posts ] |
Users browsing this forum: Google [Bot] and 1 guest |
