Leaf spring damage
Leaf spring damage
Postby Gunnibronco » Sun Feb 21, 2016 2:03 pm
So I picked up a decent set of Tahoe springs yesterday. I picked them up east of Sagauche, about 1.5 hrs away (still closer than GJ or anyother salvage yards). They seem in good shape. But when I unloaded them into the garage today, I noticed one end had been cut with a grinding wheel. Its 1/16" deep at the worst, and about 3/8" long. I'm afraid its going to start cracking. Is it trash?
Re: Leaf spring damage
Postby landshark » Sun Feb 21, 2016 2:09 pm
Personally I wouldn't be worried about it. With the thickness of the metal there I would think you would be ok. Plus with the bushing/bolt in the stress will be spread out.
Postby akaFrankCastle » Sun Feb 21, 2016 2:16 pm
X2. If you want peace of mind, just drop a bead in there with the welder.
Postby Justin » Sun Feb 21, 2016 2:17 pm
x2. I'd run it. There isn't much stress on that part on the spring.
Postby Gunnibronco » Sun Feb 21, 2016 2:20 pm
Thanks guys.
akaFrankCastle wrote:X2. If you want peace of mind, just drop a bead in there with the welder.
I was thinking about that, but worried about what the heat would do to the spring steel.
It is super thick around the bushing. I'll keep a close eye on it. bangtard
Postby crawlercreations » Sun Feb 21, 2016 2:39 pm
I worked in a spring shop for several years and made custom leaf springs and leaf spring packs while there. The loads on that section of spring go opposite of the cut. Spring steel will snap with the right amount of load in the right direction. Your cut slightly weakens the spring across that section but is very unlikely enough to cause it to snap. Never weld spring steel. It crystallizes and becomes extremely brittle. I'd run that spring as is and never worry about it again.
crawlercreations
Postby Gunnibronco » Sun Feb 21, 2016 6:33 pm
Great info. Thank you.
Postby Digger » Sun Feb 21, 2016 9:35 pm
Not a heavily loaded area. Just leave it as-is.
Postby Gunnibronco » Mon Feb 22, 2016 7:24 am
Thank you.
When I found the cut, I was pretty upset. I had convinced myself I needed to replace the damaged spring.
I appreciate everyone's advice.
:burnout:
Postby Jesus_man » Mon Feb 22, 2016 9:50 am
Gorilla Glue!
Postby Moab Mike » Mon Feb 22, 2016 5:08 pm
Gunnibronco wrote:Thank you.
:burnout:
If you're worried it is a stress riser you can polish it down but I would just go with the majority.
Moab Mike
