hockeydad4-22 wrote:You need to keep everything well lubed with soapy water. Then from the inside, one corner (I generally prefer to work from the top) you can pry and work the rubber from the inside to the outside. Work equally down the side and across the top (easiest if you remove the rear view mirror first) until you have the whole side and top out. At that point it will be very easy to lift the whole thing, glass and gasket out of the hole at once.
Just remember - it is glass, do not pry against it directly - pry against the gasket, and do not force it. Take you time, work gently and slowly, you will be just fine. Once you have done one or two you will have a pretty good feel for the rest and they will go much faster.
Jesus_man wrote:Based on the video from WH looks like you are simply trying to push the rubber lip from the inside of the cab to the outside. That's the opposite they did with the rope in the video.
Gunnibronco wrote:Buy a block that matches the heads!
Viperwolf1 wrote:17Nov78 is the casting date on the block. Heads look pretty normal. Some carbon on the pistons is normal. They look a little oilier than usual around the rings.
