It is currently Tue May 14, 2024 1:43 am
A few needs and wants
Looking for tailgate hardware. Bottom pivots, latches, handle, rods. Etc. condition does not matter.
Windshield frame. Ugly is good. Rust is not a problem.
Old nasty body panels. Planning some rust repair in the future? Good. I want the junk you cut out. Chunks of door posts and striker latches are good. So are rocker panels. Floor boards and support channels.
Basically I'm looking to build the Project X tub out into the ugliest Frankenstein looking Bronco possible.
Again, not looking for anything worth more than scrap value. Only dumpster bound parts.
Fri Aug 01, 2014 5:38 pm |
Re: A few needs and wants
Also looking for a passenger side kick panel. I don't want to keep it, only borrow it to use as a template. I have a sheet of steel at the house and access to a plasma table so I'm looking to make a new kick panel rather than buying one. Prefer new for this.
Fri Aug 01, 2014 5:46 pm |
cravenbronco
Fri Aug 01, 2014 8:14 pm |
Fri Aug 01, 2014 8:54 pm |
There are some bends in the kick panel to correct line up the door post with the other body lines. Probably not hard to reproduce them.
Fri Aug 01, 2014 9:28 pm |
Fri Aug 01, 2014 10:23 pm |
cravenbronco
Fri Aug 01, 2014 11:47 pm |
Cool. Give me a heads up a few hours in advance and I can meet ya up there. I can haul my sheet metal up and draw my template same day so I don't need to hang on to it.
Fri Aug 01, 2014 11:54 pm |
I know the in all the stuff I gave Mike with the 74 there was tailgate hardware that came off Chad's bronco.
Sat Aug 02, 2014 6:59 am |
D&D72
I have the pivots, spare carrier latch and the backing plate for the latch. maybe a few other things.
Sat Aug 02, 2014 7:54 am |
Moab Mike
Sat Aug 02, 2014 7:58 am |
Sat Aug 02, 2014 9:10 am |
The difference between me and a hoarder is I am actually going to start assembling a Bronco out of this stuff soon.
Wait. Hoarders say that too, don't they.
Sat Aug 02, 2014 12:57 pm |
kbank6
Want?
Sat Aug 02, 2014 3:14 pm |
Surprisingly, I am good on those two pieces so I'll pass.
Thank you though!
Sat Aug 02, 2014 5:10 pm |
cravenbronco
Sun Aug 03, 2014 1:08 am |
I have a driver's door, spare tire carrier with slight bend, tire carrier brackets and latch.
All free if you're interested. I can get pictures.
Mon Aug 04, 2014 12:14 pm |
I could use the brackets and latch. Let me check my beater doors for condition.
Mon Aug 04, 2014 12:40 pm |
TOOLMAN
I may have a windshield frame.
Thu Aug 07, 2014 2:58 pm |
Is it ugly? Rusty? Crooked?
Thu Aug 07, 2014 6:23 pm |
TOOLMAN
Rusty, yes. Especially the bottom. Crooked? I don't think so. I could throw it up and down the alley a few times if that helps.
Fri Aug 08, 2014 8:47 am |
I don't want you to put yourself out too much so I'll settle for rusty.
Barring any unforeseen events, I will be in Denver on the 19th and 20th.
Fri Aug 08, 2014 2:50 pm |
Fri Aug 08, 2014 3:00 pm |
Fri Aug 08, 2014 3:02 pm |
TOOLMAN
I'll be around on the 19th or 20th, after work, of course. Usually home by 4:30.
Mon Aug 11, 2014 7:32 am |
Update: I have a kick panel now. I'll also be headed north tomorrow and Sunday and can pick up stuff.
Fri Sep 12, 2014 10:59 pm |
Sorry I missed your last message. I'll be around all day Saturday (the 13th) if you want to stop by.
Fri Sep 12, 2014 11:29 pm |
Fri Sep 12, 2014 11:31 pm |
Need to add some parts on to this. I have the large slotted bracket and of the two identical brackets. Need everything else.
Fri Sep 12, 2014 11:34 pm |
I might have those AND can find them.
Sat Sep 13, 2014 10:52 am |
