Tire rack mounting on drivers side?
- Kinder
- Official CCB Member
rooster
Re: Tire rack mounting on drivers side?
Ok sweet! What do you guys think of a bumper similar to a prerunner but with square tubing?
- Justin
Post a pic of what you're thinking about. The problem with square tubing is bending it.
rooster
Well I was thinking of something like ecks front bumper because I don't have a tube bender
- Justin
Gotcha. Square tube is a fairly common solution if you're looking at a straight bumper. If you're interested, I'd be happy to build something for you.
rooster
That would be awesome Justin, but I love to fabricate and I've built several bumpers over the years for some of my friends.., nothing too fancy , but I like the idea of making it my own, ya know. If I had a tube bender I would just make them out of round 2" or something
- Justin
We've got a bunch of benders in the club-post up what you're thinking and someone may be able to knock it out for you. I've got 1.5" and 1.75" dies for mine.
- landshark
- Justin
I almost
water all over my keyboard.
water all over my keyboard.-
rooster
Tank you guys for all the help, time to start drawing plans!
rooster
Does anyone know where I can find steel at a good price?
- Eck
I've found DenCol is fair.
- Kinder
- Justin
Both are good. Dencol has a better scrap bin. If you don't need a specific size c&m has a great scrap yard. Altitude is a little more expensive, but has Saturday hours. Man, I buy too much steel.
rooster
Ok guys I've decided on a design for the front and the back will be just a 5x2 1/4" steel tube with tire rack on drivers side, what do you guys think? Also is there anyone that is willing and able to bend a couple pieces of 2" pipe?
- sykanr0ng
rooster wrote:Ok guys I've decided on a design for the front and the back will be just a 5x2 1/4" steel tube with tire rack on drivers side, what do you guys think? Also is there anyone that is willing and able to bend a couple pieces of 2" pipe?
Do you have a bigger picture of the black one with the roof rack?
I'm looking for ideas.
rooster
They are the same
- sykanr0ng
rooster wrote:They are the same
The roof rack is not visible in the second pic.
Maybe I should have been more specific.
rooster
Sorry I don't have anymore like that, have any of you heard about using a trailer spindle for a tire rack pivot?
- Eck
rooster wrote:Sorry I don't have anymore like that, have any of you heard about using a trailer spindle for a tire rack pivot?
Yep- that's pretty much what they are.
- ZOSO
- Moderator
Another thing I have seen is guy's use and spindle, hub and outta shaft. Use the lockout to hold it in position while open. Then you will have a place to hold a spare hub.
- Gunnibronco
On another forum, I saw someone use a hub, spindle, lock out, etc to bolt up their spare.
DanHall
I used some spare 1.5" DOM, 1/4" wall, for the pivot on my carrier with a 1" grade 8 bolt down the center. Mounted in double shear it shouldn't go anywhere. I had enough tube left over after redoing the tie rods and going with 1 ton ends so that part was free. The main portion of the rear bumper is 2x5, 3/16", steel since I had to buy a full stick when I did the rockers. I'll go grab a pic if you're interested.
I think the main reason most are mounted on the passenger side is that if you're pulled over on the side of the road you can open without it swinging into traffic.
rooster
Good info guys, and yeah if you could get a
rooster
Pick of how you mounted it that would be awesome! And that is a good point about it swinging that way
DanHall
Here ya go. The DOM is in three sections to form the hinge. It is built with 3/16" thick material so it isn't light but it doesn't rattle around.
rooster
That's really cool, what size bolt is that if you recall
- sykanr0ng
Now all I need to do is design the rest of my back bumper around that hinge.
DanHall
rooster wrote:That's really cool, what size bolt is that if you recall
1" Grade 8. I don't remember the length but probably about 6" since the bumper is made out of 2x5.
- Gregg
BNC04 wrote:Mine is on the drivers side. Justin and Kirk did the fab and paint, I did the design and cheering:)
You can see the section of 2 inch receiver hitch that is added to the plate for the tire. My plan is to build a license plate bracket and integrate a mount for a LED light for a backup, rear flood light. Right now, I have the plate zip tied to the rim of the spare tire. The license plate can move from the bumper receiver to the receiver in the tire carrier as needed.
Brett
Hey man. I'm headed off to the Breakfast in Johnstown and I was wondering if you're going and if you have your old rear licsense plate bracket?
Cool.
Shawn
