DanHall wrote:Yep, only had one of the pills in it. I pulled the one that was in there and have a JB Fab twin stick sitting on the bench. I'm going to try a limiting bracket like this https://youtu.be/PgfoN99zc5c and see how it works. Basically just replaces the shift flag with a piece of steel with oblong holes to limit the offset between the shift rails so they can only be even or one step apart eliminating the low/high combo.
Viperwolf1 wrote:Seals:
Input shaft seal (double lip)-CR #517383,Napa #NOS 18676, CR #18676 (good seal) (Do not use Timken #473179)
Output shaft seals-Timken #450185
Shift rail seals-CR #6204, Timken #471466
Yoke o-ring-1-1/4"OD x 1-1/8"ID x 1/16". Danco happened to be the brand at the hardware store and it is their #29.
Speedi-sleeve for yokes-SKF99155
Bearings:
Input- SKF #307NRJ
Rear output-Timken #25877 (inner), Timken #15117 (outer)
Front output, J shift-Timken #14116
Front output, T shift-Timken #14131
Cups:
Rear output-Timken #25821 (inner), Timken #15245 (outer)
Front output-Timken #14276 (both T and J)
The pill in the front hole typically gets stuck in there because the hole doesn't go all the way through. It's there, you just need a small magnet to get it out. There is no ball/spring under that front plug.
