Justin wrote:Might be a good time to also replace your e-brake cables if they're non-functional. Not hard to do later, but as long as you've got it apart....
ZOSO wrote:Add a shim-able crush sleeve to the list. That way you never have to worry about the thing collapsing on you under high torque loads.
Only way to tell the bore case size is to pull out 3rd member and measure the carrier bearing bore.
Digger wrote:ZOSO wrote:Add a shim-able crush sleeve to the list. That way you never have to worry about the thing collapsing on you under high torque loads.
After what I did to my truck this weekend, 2x on the crush sleeve eliminator kit.
ZOSO wrote:This is for an 8.8 but you get the idea.
http://www.jegs.com/i/Yukon+Gear/807/SKCSF8.8/10002/-1
phyler wrote:Most likely. I would guess there is the possibility that the front was 2.5 at some point.
Eck wrote:phyler wrote:Most likely. I would guess there is the possibility that the front was 2.5 at some point.
Probably so. I have since added a 351W, power steering, and EFI, so it wouldn't surprise me if the added weight has compressed it by a half inch.
So my next question is what to order for the suspension parts. I think I will go ahead with 3.5" lift springs for the front unless the extra inch would cause me to have to change a bunch of other stuff? I already have to change my driveshafts when I install the ZF5 so that isn't a problem. Does that mean that in order to keep the Bronco level, I would then go with the 2.5" rear lift? I am planning on going with the WH 11 spring kit but they offer it in 2.5, 3.5, etc.
Eck wrote:Yah, have a heavy Warn Belleview with a pretty stout homemade prerunner style front bumper.
Eck wrote:I am looking to place my order for the Ring and Pinion and want to make sure I get the correct one.
Going with ARB 31 spline 4.56 gears.
I was looking at Yukon YG F9-456 ($250) on Summit Racing. Is this the correct ring and pinion?
Does anyone have any comments or suggestions on a brand or something that may work just as well at a better price?
Looks like some people over on CB have had luck with Motive Gear? Those are about $100 cheaper than Yukon. Couple people say the Richmond gears are loud.
