Gunnibronco wrote:With extended arms, the wedges could be placed where the factory put them on the F100s & F150. I have a bare full width housing and could measure after work today.
I don't know if there are advantages to narrow or wider mounting spacing.
Digger wrote:I used a 78/79 full width HP44 in my build. I left the axle 100% stock, moved the upper buckets 2" outboard and re-drilled the lower cups 1" inboard to make up the 3" difference per side. I'm using 7° C-bushings with extended radius arms and no drop brackets. Caster is 4.5°, Camber is 0.25°, toe is 0.25° The truck is very stable, even at 80 mph.
The frames on these trucks are really narrow, so getting the coils further outboard has advantages.
Gunnibronco wrote:Ok here are the measurements I took. My housing is a 76 or 77, can't remember. I'm not fully functional with my photo editing skills. I took 3 measurements.
The wedges are welded on with a significant angle to them.
Measured from the middle of the c-wedges, front of the axle is 42-3/4", rear of the axle is 40".
From the center of the upper ball joint to the middle of the wedges on top of the axle is 6".
Jesus_man wrote:Perhaps you've ran across pics of my front setup. It's a y-link radius arm similar to what Justin did and I think it's far superior to stock. Adjusting caster is super easy compared to swapping out bushings. If you've got a clean slate, my preference would be to build my own arms to the length I wanted them and ditch the stock setup. The only real draw-back is since it'll flex better, you may gain some body roll.
