Auxiliary filler hose part number
- akaFrankCastle
- Official CCB Member
Anyone have a part number for a fuel rated hose that works for the auxiliary tank filler neck?
- DLB
Re: Auxiliary filler hose part number
I was unable to locate that particular item as well - ended up with 2-90's coupled together
Unaweep
I just went down to NAPA and found one with a similar bend (almost). That hose was longer but I trimmed it. It fits almost perfect, no problems when filling the tank. Cost was $21.
J.E.
J.E.
- Kinder
Can you pass along the part number for it.
Unaweep
kinder wrote:Can you pass along the part number for it.
I didn't save the invoice.
I just took the hose down and told the NAPA counter guy to match up as best he could a couple hoses that were similar in the bend radius and let me choose between the two.
J.E.
- Moab Mike
- akaFrankCastle
Napa part number 1047. 2" fuel hose with 90* bend.
