Emergency Brake Bracket
Post Reply
Unaweep
Post by Unaweep »
Does anyone sell a replacement emergency brake bracket that's welded to the frame? Mine is totally mangled, looks like it went through a blender.
I'm rebuilding the rear brakes and this is a partial reason my emergency brakes don't work.
J.E.
Unaweep
Re: Emergency Brake Bracket
Post by Unaweep »
From all the views and zero replies, I guess I'm not the only one who can't find a replacement.
I'll just build a new one.
J.E.
Post by landshark »
i was going to say, might be easier to fab a new one. The one on my 69 failed so i had to weld and fab supports for it.
Post by Justin »
x2, I'd probably just build one.
RJLougee
Post by RJLougee »
Unaweep wrote: From all the views and zero replies, I guess I'm not the only one who can't find a replacement. J.E.
It could be because folks are having a hard time figuring out what you're asking, since none of the E-brake parts attach to the frame. So maybe they're just confused.
When I did my Cherokee hand operated E-brake conversion I used a piece of 1.5x1.5" angle iron and welded it to the inside of the frame (remember to triangulate). The cables from the axle went to this, and I kept the body mounted swing arm, although I reversed the cables on it to get greater "throw".
HTH, Joe
Unaweep
Post by Unaweep »
The mangled part is the bracket that is welded to the frame, I just doubt that part is made as they don't break or wear out.
I'm just going to cut the old one off, cut a new one out and re-weld it. I just have to flatten out the old one for a pattern.
Personally I can't figure out how the previous owner mangled the bracket into a knot, but he did. He must of got hooked up into a stump or something.
Post by Viperwolf1 »
Can you take a picture of it? The only part that should touch the frame is the spring.
sykanr0ng
Post by sykanr0ng »
If you mean the brackets for the emergency brake cables, at least on my Bronco those are on the underside of the body.
Not the best pic, but the one I have on this computer:
Unaweep
Post by Unaweep »
sykanr0ng wrote:If you mean the brackets for the emergency brake cables, at least on my Bronco those are on the underside of the body.
Yea that's it.
Post by Eck »
Unaweep
Post by Unaweep »
Eck wrote:http://www.tomsbroncoparts.com/product/emergency-brake-lever-3-pc-66-77-early-ford-bronco-new
I'm going to call TBP and make sure that's the part. Thanks Eck.
Post Reply
