Heater upgrade
Heater upgrade
Postby B.O.B. » Mon Nov 23, 2015 9:23 pm
So now that I am driving the Bronk more I definitely need more heat during those cold days. Looking into doing the heater upgrade and was wondering if you need the cage and motor or if just the motor would work. Any thoughts on if there is a big deal comparing one from the other?
B.O.B.
Re: Heater upgrade
Postby akaFrankCastle » Mon Nov 23, 2015 9:55 pm
Just buy a good blanket and keep it in the truck. Lol
The motor and the cage are said to be the good recipe. The motor is crazy faster than the stock Bronco unit. And the cage does the job of translating that to more air. You might be able to get away with the smaller cage on the better motor for some increase though.
Have you insulated your Bronco yet?
Re: Heater upgrade
Postby ZOSO » Tue Nov 24, 2015 5:42 am
Yes motor and cage. I posted the part numbers I used about a year ago. easily available at napa and cheaper than buying it from a vender. You do have to cut the opening a little bigger but it's well worth it.
Re: Heater upgrade
Postby Gregg » Tue Nov 24, 2015 2:26 pm
Agreed. If you're gonna do it, the extra $15 is worth the bigger wheel.
Gregg
Re: Heater upgrade
Postby casadejohnson » Wed Nov 25, 2015 12:01 am
And buy a new Amp for your stereo. The price of the bigger cage and motor is more noise in the cab.
casadejohnson
Re: Heater upgrade
Postby sykanr0ng » Thu Nov 26, 2015 9:19 am
Doesn't need to be a Chev. blower motor.
One from a '92 or so F250 will work too.
sykanr0ng
Re: Heater upgrade
Postby cravenbronco » Fri Nov 27, 2015 9:14 am
I found a 97 F350 with a 351w. Will that heater system work ?
cravenbronco
Re: Heater upgrade
Postby sykanr0ng » Sat Nov 28, 2015 2:02 am
cravenbronco wrote:I found a 97 F350 with a 351w. Will that heater system work ?
It appears that the same part number was used for '87 - '97 on Broncos, F150's, F250's and F350's.
Makes it easier to find one.
sykanr0ng
Re: Heater upgrade
Postby ZOSO » Sat Nov 28, 2015 7:20 am
As long as its the ZF5 and you pull that too.
Re: Heater upgrade
Postby sykanr0ng » Sat Nov 28, 2015 1:16 pm
Nah, you don't want that.......................and where did you say it was? :laughing2:
sykanr0ng
