crawlercreations wrote:My uncle is running the Explorer(really just the Era of ford) pump in his 96 bronco with ram assist and it seems to do just fine keeping up. I'd run what you have and upgrade later if it doesn't work to your liking.
ZOSO wrote:crawlercreations wrote:My uncle is running the Explorer(really just the Era of ford) pump in his 96 bronco with ram assist and it seems to do just fine keeping up. I'd run what you have and upgrade later if it doesn't work to your liking.
Thats the thing. I have 2 saginaw pumps and the explorer pump here.
casadejohnson wrote:Unless they changed it, the wild horses bracket is only for a 5.0. It does not fit the 5.8. I never had any luck with the explorer pump and I have had at least 5 on my bronco. I talked about the pumps with Phil recently and it seems that the pumps from earlier (96) explorers might be better than the later ones. I used the WH kit and cut a new Bracket on the water jet to make it work with the 5.8. Worked great with 35's and hydroboost until I blew out the o ring between the pump and the reservoir. Still need to fix that.
