Justin wrote:Hmmmmm, which tire shop? You may have been talking to B.O.B.
Aspen Park Tire and Auto. I can't remember his name tho. Said he had a couple rigs.
They put new tires on for me that I got from tire rack. 35's!
BNC04 wrote:rlm18 wrote:Eck wrote:Installed the electric pump yesterday and used some steel hard line for part of the engine bay. I routed the line as far away from the block as I could so I'm hoping the combination of the two will so the trick. If not, I'll have to keep throwing other ideas at it. Thanks for the suggestions.
Hi Eck. I was wondering if the steel hard line worked?
Anyone,
I think I am battling vapor lock as well. After a few hours of driving, no matter the style, I start having trouble. Maybe that is too long to expect out of the bronco? Hiccups, bucks, loses throttle response, stalls if I keep pushing it. I can slow down and limp along unless there is incline, then I have to stop and let it rest.
I bought some heat guard hose from napa and tried it in the engine bay but it did not work. I was thinking about cutting out some of the slack in the engine bay. Trying to reroute it to get it higher off the engine. Do the regulator and gauge need that much hose after to the carb to function properly? Is it even set up right? Or maybe metal heat guard or maybe just metal line? It also appears that I have two fuel filters? One before the pump and one in the engine bay? Is that necessary? I was going to try changing those, maybe taking one out? Trying to figure out if maybe my intake line in the tank is dirty. I have a single 23 gal tank. Changing to a different electric pump. Not sure which I have. Checking the regulator and return line? I also have a phenolic spacer on the carb.
I also do not understand why there is so much trouble with vapor lock.
Anyone one have anymore ideas?
Thank you.
Russell
Do yourself a favor while your messing with lines etc and get that Mr Gasket FP regulator out of there. Replace it was a decent FP regulator as soon as you can. I have had 2 of those start spraying fuel in the engine bay at random and was just plain lucky there was no fire as a result.
Brett
