Push rod promlem
Post Reply
JGZ
Push rod promlem
Post by JGZ »
So I got my new to me 69 running only to find out why it probably got parked 18 yrs ago.Couldn't find one in my inventory so I guess I'll order one,unless someone has one laying around?
Re: Push rod promlem
Post by Rox Crusher »
dont have anything to offer besides .........
OUCH !
Moab Mike
Post by Moab Mike »
You may want to run some Sea Foam or ATF through the engine oil once you get it back up and running. It may help un-stick the lifters.
JGZ
Post by JGZ »
Moab Mike wrote:You may want to run some Sea Foam or ATF through the engine oil once you get it back up and running. It may help un-stick the lifters.
I did that.The thing purrs like a kitten except for the lack of one cylinder.The lifter is still in the bore,so hopefully I'll get lucky.
Anyone know the length of a 69 302 push rod?
Post by Viperwolf1 »
You could always pull another one out to measure.
JGZ
Post by JGZ »
Two bent push rods later,cleaned out fuel system,rebuilt carb and it runs like a champ.Not bad for sitting for 18 years.Supposedly only 56k on the truck.
Happy Happy
Moab Mike
Post by Moab Mike »
JGZ wrote:Two bent push rods later,cleaned out fuel system,rebuilt carb and it runs like a champ.Not bad for sitting for 18 years.Supposedly only 56k on the truck.
Happy Happy
Were you able to run the fuel tank and carb I gave you?
JGZ
Post by JGZ »
Happy Happy
I ended up rebuilding the carb it had on it,just because of the manual choke.If you need it back it's here.If not I'll pass it on to the next guy.Thanks for the parts though Mike,it's much appreciated.
Post Reply
