Any ideas or thoughts from those of you that have mounted your long arms? Did you have it lined up outside the frame at all? If so, how did you reinforce it and did you have any interference issues doing so?
Both driver and passenger side:
Digger wrote:Honestly there is enough give in the C-bushings, I would loosen them up a few turns, weld your brackets on under the frame and then re-tighten the C-bushings.
Are your long arms bent or straight?
Digger wrote:I looked again and saw you have MetalCloak joints. You'll probably want to un-bend the arms to get the brackets inboard a little. You don't want them hanging outboard of the frame, it will add articulation stiffness to the front axle.
Jesus_man wrote:1.5" of movement at the end of the arm isn't all that much stress on your C-bushings. I'd push them in and weld them on.
Jesus_man wrote:But Eck says they may need a little more bend to get them to align with the frame.
Eck wrote:Digger wrote:I looked again and saw you have MetalCloak joints. You'll probably want to un-bend the arms to get the brackets inboard a little. You don't want them hanging outboard of the frame, it will add articulation stiffness to the front axle.
The bend actually bends in towards the frame. If the bend wasn't there, I think it would be further outside.
Eck wrote:S
Question 2: If the arms were bent straight, wouldn't the geometry of the mount not line up parallel to the frame? Isn't that the goal? It seems that with the metal cloak joints it needs to have a straight shot at the C channels?
ZOSO wrote:Mike I put a bend in mine also. But not as much as we did on yours. If Mine don't line up exactly right then I'll do what J.D. drew up. I don't want to weaken the tube more than we already have by unbending the tube.
Jesus_man wrote:Chad, - not quite. Here's a section view of what I was thinking for the passenger side. It's crude - sorry!
Looking at a side view, if your link bracket is 6" long, you'll want this U-shape to be 7" long and perhaps have some holes in the side for plug welding.
Clear as mud?
Eck wrote:ZOSO wrote:Mike I put a bend in mine also. But not as much as we did on yours. If Mine don't line up exactly right then I'll do what J.D. drew up. I don't want to weaken the tube more than we already have by unbending the tube.
I assume you haven't tried to install yet? I'd be interested in maybe mocking yours up on my axle to see where they line up... Let me know if you're interested...
Clear as mud?
