Not my rig but my project "Siamese Dream"
Re: Not my rig but my project "Siamese Dream"
Post by ZOSO »
awesome!!! On day i'd like to build one like that.
Post by Kinder »
Oh it's going up! I'm just thinking through my options. Fixed rack will give side space for other items like equipment or maybe even solar and be simple. Or a rack that stows down then raises up for use, gives the option to improve COG and incorporate a lid that raises for covered storage. Hmm...
akaFrankCastle wrote:You still have room on that ladder. Take it up another 24" or so to keep Yogi from waking you up with a foot massage.
Post by landshark »
Or a portable blind. Pow pow
Post by Kinder »
Built plan B today, plan A will have to wait until the Bronco fund has some money. I wanted it mounted just below the roofline so that if the Bronco makes it the trailer will also, but I wanted it up a bit to allow easy access to contents packed in the trailer. Of course RTTs were designed to be up a bit more and the accessories I'd like to add will require plan A below. I also offset it to the passenger side so I could pack long items on top of the rack if needed.
Plan A will be modeled after this build on expeditionportal.com.
Post by Kinder »
RTT worked out great on my recent scouting trip, it's a keeper.
Post by hockeydad4-22 »
Where is that "Like" button again!!!
And yeah - I am a bit green with envy
Post by landshark »
Wow thats sweet!
Post by Jesus_man »
You could make a little screened in gazebo under the tent by hanging net below it.
Glad it's working out out so well for you!
Post by Eck »
Nice work Kirk-- very utilitarian!
Post by ZOSO »
Love it! Been looking into little trailers to do just this.
Post by Kinder »
Jesus_man wrote:You could make a little screened in gazebo under the tent by hanging net below it.
The RTT companies make a "changing" room that attaches to the outer edge, it's a nice upgrade. As soon as I build plan A rack to raise it up a bit more I'll look for one.
Post by Kinder »
hockeydad4-22 wrote:Where is that "Like" button again!!!
It was a very nice spot, the view from the front door was just as scenic.
Post by Kinder »
It's been a long time coming but I finally bolted a main tank into the trailer. I'll add a frame rail mounted pump and use the trailers existing aux line from the 7 pin plug to energize it and pump to BSD's new 23 gal tank. Now I just need to find a weather resistant quick disconnect fuel attachment for the trailer to bronco.
Phase 2 will be adding the other main tank to the front section of the trailer and repurposing my old 3 way valve to have 22 gallons on the trailer. That won't happen until I rebuild the poorly built frame section coming off the trailer to the bronco.
Post by Jesus_man »
So many benefits to building a trailer like this!! I love it!
Post by Kinder »
Upgrading the front of the frame / hitch connection has been needed since I brought it home. I'll also be adding a platform to haul an ATV or gear.
Post by Kinder »
A little progress made between soccer games, cardboard & Sharpie will keep me on track.
Post by Kinder »
Goodbye crooked pipe, hello usable frame.
D&D72
Post by D&D72 »
Cool, did you find a quick disc for your fuel line yet?
Post by Kinder »
On the list, esp with hunting season around the corner.
Post by Kinder »
A little finishing welding today, added outboard plating to the frame splice and reinforcement tabs, also got the lunette installed. Next up is wiring, atv deck and fuel lines.
Post by Digger »
I like the progress!
Average 23.5 mpg, Best tank: 26.3 mpg
Post by Kinder »
Deck framework is on, I'll add diagonal braces down to the frame from the sides so it doesn't buckle when loaded. I've also decided where to put the front jacks and luckily have enough frame sized steel to make it happen. Ran a little short on the expanded steel so I had to quilt one section together.
Post by landshark »
Should have made it big enough for another bronco [emoji3]. Looks great
Post by Kinder »
landshark wrote:Should have made it big enough for another bronco [emoji3]. Looks grest
So true, it's really hard to make a platform to carry a quad when it's longer than a bronco is wide!
Post by Kinder »
Spare time between soccer games is useful, but makes it hard to finish a project w/ a spare 1 hr here and there.
Anyway, the deck frame is fully welded to the trailer frame & the expanded steel is secured as well. Front jacks are on, just need to cap off the frame extensions, now I need to add the bracing for the edges of the deck.
The front to back balance is almost spot on, I'm moving the spare to the rear & adding a space for a generator & propane, that ought to put me back to neutral.
Post by Eck »
Looking good! Well done. You need a more utilitarian vehicle...
Post by Rox Crusher »
Waddaya figure that thing will weigh when it's loaded up ?
Post by Kinder »
It'll get weighed soon, I've tried to not overbuild the frame extension by using the same dimensional steel as the original frame, and for the deck I used what I thought would be adequate.
Frame Extension: 3x4 .120 wall 5.4 lbs/ft = 118 lbs
Deck Frame: 1-1/2 x 1-1/2 .120 wall 2.2 lbs/ft = 88 lbs
Flattened Expanded Steel: 20 lbs
Total: 226 lbs added
I'll do a loaded & unloaded weight.
Post by Jesus_man »
Going to add any tie-down points? They could come in handy.
Post by Kinder »
For sure, thinking some small'ish D rings on slides so they'll drop down out of the way when not in use. Maybe 4-8, so each corner and then a couple in the middle.
Post Reply
