Window Frame Adjustment help
Post Reply
csangster
Post by csangster »
So I have spent the past two years welding in new sheetmetal thorughout my bronco.
As I was fixing all the cancer, it became apparent to me that my bronco had been in previous accidents because the inner fenders were crumpled, the driver quarterpanel was bowed in (with bondo covering the carnage) and looks like it may have gently rolled over or ran into something on the top because the window frames are not straight (they have been massaged back into place by a previous owner).
Specifically on my passenger side door, the door fits well in the opening but the window frame interferes with the hard top.
Has anyone ever had to adjust the windowframe only? Mine are welded on (not bolted).
I am considering just cutting the corners to tweak it over and then re-weld in the new location.
Thoughts?
Chris
Re: Window Frame Adjustment help
Post by Digger »
Posting a few pictures may help others visualize the problem.
Average 23.5 mpg, Best tank: 26.3 mpg
Post by akaFrankCastle »
How is the gap between the bottom of the door and the rocker panel?
rt9
Post by rt9 »
Place a spacer between the floor board and the body mount. Firewall is sagging?
Post by Gunnibronco »
Definitely post up some pics. Without pictures, I think we are all just guessing.
csangster
Post by csangster »
rt9 wrote:Place a spacer between the floor board and the body mount. Firewall is sagging?
That's not it. Firewall is definitely not sagging. I've replaced sheetmetal everywhere.
Pictures inbound
csangster
Post by csangster »
How does one attach photos?
plumbdoctor
Post by plumbdoctor »
rt9 might be on to something....do you still have original body mounts? The old mounts can cause issues
csangster
Post by csangster »
Rt9,
Apologies, I didn't mean to be so dismissive. Things aren't exactly square, but that is due to all the repair guesswork I had to perform because of PO scab work
I'll take a look
Thanks
Chris
rt9
Post by rt9 »
csangster wrote:Rt9,
I'll take a look
Thanks
Chris
No worries, just a thought.
Rick
Post Reply
