James Duff Radius Arm bushing failed
Post Reply
Unaweep
Post by Unaweep »
Took my younger son out last week to the desert for some fun and just tooling around.
I had to burn off the gas on the smaller tank, it was old. Lot of fun...it amazes me how great the Bronco does off road, especially in twisty situations.
Later at home I noticed the radius bushings looking bad.
I don't know the age of the suspension kit - guessing 80's.
ManTruck
Re: James Duff Radius Arm bushing failed
Post by ManTruck »
I have had that issue in the past with those exact bushings in the past. The good old rubber ones manage flex a bit better in my opinion. The poly seem to be ok until you start to abuse and flex, where as the rubber seem to manage it better.
Owned my 1972 since 1985
Canon City, Co
cravenbronco
Post by cravenbronco »
ManTruck wrote:I have had that issue in the past with those exact bushings in the past. The good old rubber ones manage flex a bit better in my opinion. The poly seem to be ok until you start to abuse and flex, where as the rubber seem to manage it better.
X2
Unaweep
Post by Unaweep »
I'm not at all surprised the bushings failed, they were really old. They lasted from 198x-2017 vs the original 1969-198x.
and I rather they die on the trail vs just sitting around doing nothing.
Post by Digger »
drawback of poly. Once a crack starts, it propagates quickly.
Average 23.5 mpg, Best tank: 26.3 mpg
Post by Justin »
Unaweep wrote:I rather they die on the trail vs just sitting around doing nothing.
Probably a good philosophy for life generally.
Post Reply
