Black Smoke Donkey
Re: Black Smoke Donkey
Postby millerpz » Mon Jan 14, 2019 10:31 pm
Oh and I have an 89 (same as a 91) if measuring one would help.
millerpz
Postby Kinder » Tue Jan 15, 2019 10:16 am
Thanks, I’ll check the listing out.
Postby Kinder » Fri Jan 25, 2019 5:03 pm
Digger wrote:
Kinder wrote:Housing is toast. I know it’s a long shot but if anyone has a lead on a 1978-1979 D60 housing or complete axle let me know.
Dang. Is the center section messed up?
I missed this, yes, he (they) said the center section was also bent.
I’ve got a tip on another complete axle, I’ll post up if I get my hands on it.
Postby BroncoCrawler » Sat Jan 26, 2019 12:49 pm
https://www.facebook.com/groups/rockcra ... 6119839334
Sent from my Pixel 3 XL using Tapatalk
BroncoCrawler
Postby Kinder » Sat Jan 26, 2019 1:23 pm
BroncoCrawler wrote:https://www.facebook.com/groups/rockcrawlingclassifieds/permalink/2303956119839334/?sale_post_id=2303956119839334
Private Group, something there worth joining for?
Postby BroncoCrawler » Sat Jan 26, 2019 1:32 pm
It's ok just depends how bad you need one.Image
BroncoCrawler
Postby Kinder » Sat Jan 26, 2019 4:00 pm
Thanks for keeping an eye out for me, that price is actually good. VA would be tricky, but I do know a guy that hauls equipment from the east coast through Denver.
Postby Kinder » Mon Feb 04, 2019 2:59 pm
Okay, let’s try this again.
Postby Jesus_man » Mon Feb 04, 2019 3:46 pm
Thumbs up!!!!
Postby Rox Crusher » Mon Feb 04, 2019 7:08 pm
Now we’re talking !
Postby Digger » Tue Feb 05, 2019 9:48 am
Back in business. Alright !
Postby Kinder » Sun May 05, 2019 4:42 am
The box grader at the park needed some repairs, BSD with the onboard welder to the rescue.
Postby Digger » Sun May 05, 2019 3:48 pm
*two thumbs up!*
That beast is a true workhorse.
Postby Rox Crusher » Mon May 06, 2019 11:20 am
Park team: stand back here comes Clint Eastwood / Chuck Norris / Macgyver again
Postby D&D72 » Mon May 06, 2019 12:05 pm
Rox Crusher wrote:Park team: stand back here comes Clint Eastwood / Chuck Norris / Macgyver again
What about red/green?
D&D72
Black Smoke Donkey
Postby Kinder » Wed Jul 10, 2019 3:32 pm
It had a good run, but the day has come, turbo rebuild time. I’ve always wondered what turbo was on my 4BT, it’s a Holset HX30. Based on what I’ve read from others it’s one of the better turbos for the 4BT, and it’s performed well for me. I’m going to attempt rebuilding it myself, kits aren’t that expensive and the turbo is internally balanced. If I can’t sort it I’ll look for a local shop before sending it out. I think I caught it before any damage was done, fingers crossed.
Postby Jesus_man » Wed Jul 10, 2019 6:26 pm
Do they offer upgraded impellers?
Postby crawlercreations » Wed Jul 10, 2019 7:35 pm
Turbo rebuilds are easy peasy. My first was the stock turbo on my 7.3 bus. Installed a wicked wheel 2 at the same time. Nothing to it.
Postby Kinder » Thu Jul 11, 2019 11:23 am
Jesus_man wrote:Do they offer upgraded impellers?
There isn’t much out there for the HX30, most upgrades are oriented to the HX35 for the 6BTs. The HX30 can push 35 psi if given the fuel. My performance improvements live in the P Pump, I plan on upping my governor spring to 3k and swap in a new #10 fuel plate. That’s about as far as I can go until I swap in heavier valve springs and fire ring / stud the block.
Postby Kinder » Thu Jul 11, 2019 11:28 am
crawlercreations wrote:Turbo rebuilds are easy peasy. My first was the stock turbo on my 7.3 bus. Installed a wicked wheel 2 at the same time. Nothing to it.
Thanks for the encouragement, I ordered the rebuild kit and watched a couple of vids & downloaded the service manual and spec sheet from Holset. I started the tear down last night. I just need to remove the exhaust housing, it doesn’t want to come off easy, of course it’s seen 1000 degrees hundreds of times, I’ll hit it a little harder tonight.
Postby Error404 » Sun Aug 04, 2019 12:44 pm
I would like to find an hx30 for mine. I have an hx35.. i have a wicked wheel in my tool box and stage 1 fuel pin and a stage 2 stashed for later.. lag is pretty bad. Currently get to 26lbs...but my head gasket finally gave up.
1996 bronco 4bt sas .
1972 bronco 10k mi no motor no trans..unfortunately rolled in 1973. Left for me to bring back from the dead.
Error404
Postby Kinder » Sun Aug 18, 2019 7:22 pm
From what I’ve read the HX30 is one of the best turbo matches for the 4BT, also the head gasket on the 4/6BTs is definitely a weak spot. The future hold pump upgrades for me, gov & fuel plate.
Error404 wrote:I would like to find an hx30 for mine. I have an hx35.. i have a wicked wheel in my tool box and stage 1 fuel pin and a stage 2 stashed for later.. lag is pretty bad. Currently get to 26lbs...but my head gasket finally gave up.
Postby Kinder » Sun Aug 18, 2019 7:25 pm
BSD is back on the road, that took way too long. The rebuild kit was only available from one place online, I guess the HX30 isn’t all that common. I’ll break it in easy then hammer it to make sure all is well. Pics tomorrow to prove it runs!
Postby Kinder » Mon Aug 26, 2019 7:44 am
A little late, proof that it’s back in the wild.
Postby landshark » Mon Aug 26, 2019 8:46 am
Kinder wrote:A little late, proof that it’s back in the wild.
That photo could have been taken at anytime... where is the newspaper with the current date???
Postby Jesus_man » Mon Aug 26, 2019 8:48 am
Either way, all I know is I am jealous of you getting out into the mtns! Was home for a few days last week and did some light wheeling with my Dad in his Rubi. It was great to be in paradise!!
Postby rt9 » Mon Aug 26, 2019 9:09 am
Was at the car show in Elizabeth this weekend. A guy was there going on and on about this cool stretch bronco he saw in Parker. He was absolutely in love with it. Lol
rt9
Images: 11
Postby Kinder » Mon Aug 26, 2019 9:32 am
Newspaper? How old are you, ha! I’m in the park at the new trail that I’ve been working for forever. Today’s work is a bench install and buck & post/rail fencing.
Postby Digger » Thu Oct 17, 2019 10:27 am
Any updates?
How's she running? Do I need to tune up the 2.8 to hang with you?
Postby Error404 » Thu Nov 21, 2019 6:42 am
Have you done headgaskets/studs in the 4bt yet?
Error404
