ZOSO's toys
- ZOSO
- Moderator
Re: ZOSO's toys
yep thats who I use for all my an fittings and hoses. I got most everything I need I just gotta make sure it'll all fit and under the hood.
- ZOSO
- Moderator
Re: ZOSO's toys
Another thing almost complete. Got 90% of the trans cooler lines done. that will be finished tomorrow and will continue on with the wiring.
- ZOSO
- Moderator
Re: ZOSO's toys
It's Alive!!!! ish. Needs a tune. Way rich!!! Tuesday Garry should be coming by tuesday to get me a tune. I need to go get my driveshafts built.
- Rox Crusher
Re: ZOSO's toys
Awesome !
Keep going
Keep going
- ZOSO
- Moderator
Re: ZOSO's toys
After having the master EFIguy over for a few hours last night we were unable to get it to run. Weird thing is itll run albeit very rough WITHOUT the fuel pump. After a bit of trouble shooting and washing out the oil again we narrowed it down. Now the in depth trouble shooting starts. For some strange reason neither of us can figure out why but as soon as the key is turned to the on position it powers up all 8 injectors. They are all on/open and do not pulse. So it just fill the engine with fuel. 2 pcm's do it either tuned or factory. The harness ohm's out ok on the injector wiring. Will likely pull the upper intake off next week and start the testing of the harness. Double checking all wiring.
- Jesus_man
Re: ZOSO's toys
It'll be something stupid simple, but finding that could take some time!! Hope you sort it out soon!
- Kinder
- ZOSO
- Moderator
Re: ZOSO's toys
VROOM VROOM!!!! It's alive. Couldn't stump the master for very long. He found a corrupted pcm/tune. Once he re-created the tune we have lift off. Now to fix the leaks and burp/bleed fluids and a drive shaft Im gonna drive it around the block.
- Gunnibronco
Re: ZOSO's toys
Nice! Congrats!
- hockeydad4-22
Re: ZOSO's toys
NICE! Congrats
- landshark
Re: ZOSO's toys
Very Nice!
- Jesus_man
Re: ZOSO's toys
Good work guys!! I'm glad it didn't take too long!
- Digger
Re: ZOSO's toys
Awesome news! So we'll be seeing this beast at the next breakfast.
- TOOLMAN
Re: ZOSO's toys
- Viperwolf1
Re: ZOSO's toys
Where's the video?
- ZOSO
- Moderator
Re: ZOSO's toys
Viperwolf1 wrote:Where's the video?
Trying to upload it to youtube now. I did post it to my FB page. I'll get another one tonight after I fix a few small leaks and flip the iac around so it'll idle on its own.
- ZOSO
- Moderator
Re: ZOSO's toys
- Rox Crusher
Re: ZOSO's toys
great news Rob.
congrats !
congrats !
- ZOSO
- Moderator
Re: ZOSO's toys
Digger wrote:Awesome news! So we'll be seeing this beast at the next breakfast.
Gonna try. I'm gone all next week and weekend so hope to get a lot done and ordered this weekend. Trying to get it all done before October for elk hunting.
- ZOSO
- Moderator
Re: ZOSO's toys
So spent all day Saturday trying to bleed the brakes. Had some messed up bleeders. Went to the parts store 4 times to finally get the correct ones. Got all those put in and no go. Front calipers are screwed up and won't stop leaking. Give up for the day. Today went and bought new calipers. Went to install and the lines don't freaking fit. So I give up. Just push it back I to the corner of the garage and let it sit. Don't see this being done anytime soon. All I wanted to do was drive it around the block.
- Jesus_man
Re: ZOSO's toys
Give it a day or to Rob. You'll get it going!
What's up with the calipers? Wrong size or a length issue? What brand of caliper?
- ZOSO
- Moderator
Re: ZOSO's toys
Teaser. I didn't have to push it either.
- Justin
Re: ZOSO's toys
It's amazing what 50 model rocket engines can do.
- Kinder
- Eck
Re: ZOSO's toys
The question is, "were you able to stop on your own?"
- ZOSO
- Moderator
Re: ZOSO's toys
Eck wrote:The question is, "were you able to stop on your own?"
Yes finally.
I'm running a strong hydro boost with 78 camaro master and chevy discs. It's a really soft pedal with no feedback/feeling. It stops damn good but I don't like the pedal feel. Guess that's what I get for running all chevy junk.
- Jesus_man
Re: ZOSO's toys
ZOSO wrote:Eck wrote:Guess that's what I get for running all chevy junk.
tisk tisk! LOL!
Congrats on the running engine!
- Justin
Re: ZOSO's toys
Pedal feel is weird with the hydraulic booster. Assuming you're bled well you get used to it. It also takes awhile to get all the air out of the booster, so it may take some more driving. You're welcome to compare against my setup at lunch on Saturday.
- Gunnibronco
Re: ZOSO's toys
I think you are on the right track, getting a larger bore M/C. I added the t-bird calipers to my existing H-boost system and it softened the pedal. With the F150 calipers the pedal was very sensitive. I liked it, but it was either on or off & it had rear bias. The bigger t-bird calipers pulled the bias forward and gave a softer pedal, but it's still ok. Any bigger, and I think I'll be looking for a different m/c too.
- ZOSO
- Moderator
Re: ZOSO's toys
the camaro master is 1 1/8" bore already. I guess I'll find out how well it works tomorrow hopefully. I plan to bleed them some more when I get home from work just to be safe.
