TJ's 74 Bronco money pit
- cpldavis37
Re: TJ's 74 Bronco money pit
The gauge turned out nice.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- cpldavis37
Started the new glove box. Thanks for the help John.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- cpldavis37
Dash disassembled.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- Kinder
- Jesus_man
kinder wrote:Doing any mods while it's out?
- cpldavis37
Just painting and rewiring. Sorry that took me so long to answer.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- cpldavis37
Finally finishing my 351 efi conversion. I hope I can stay on track. I painted the block and ordered a ton of parts.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- cpldavis37
Christmas time!
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- Gunnibronco
Nice. What heads?
- cpldavis37
They are "Promaxx" formally "Patriot". I'll give them a try. Western engine recommended them to me. They said they have used them on several sbf and had good results. They are about 950 shipped, so half the cost of more name brand heads.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- Strike2
VERY NICE ! I need to start celebrating Christmas in April, Santa is much more generous
- cpldavis37
Clear coat.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- cpldavis37
Cam and timing chain installed.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- Digger
Looks like it is coming along nicely.
- cpldavis37
If I could just stop going to work, I would have it done by now.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- cpldavis37
Valve covers came out nice.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- cpldavis37
Mocked up.
Don't look at the messy garage though.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- Kinder
- cpldavis37
Thanks Kirk!
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- Kinder
- ZOSO
- Moderator
I always knew fans robbed HP but dang that was interesting.
On that note I like my Taurus fan setup. we'll see how it works in the high heat.
- cpldavis37
I was going to run a Taurus fan, I would love to check out your setup.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- cpldavis37
What an interesting video. I used to run something very similar to the aluminum fan. Lol
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- cpldavis37
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- Jesus_man
I run what appears to be a stock setup. It works, so I'm inclined not to fix it! If I do, it'll be the Taurus fan or some other dual speed electric.
- Rox Crusher
Parasitic drag / horsepower loss is certainly a factor........keeping it cool seems to be more important in our rigs
- ZOSO
- Moderator
Rox Crusher wrote:Parasitic drag / horsepower loss is certainly a factor........keeping it cool seems to be more important in our rigs
I agree. I went with the Taurus fan because I had it laying in the garage. If it doesn't work on those hot days I will go back to a mechanical fan.
- ZOSO
- Moderator
No problem. Im around this weekend. Actually gonna pull the radiator and fan out to pull the balancer and get it redone. So it wont be complete.
- Viperwolf1
It takes horsepower to turn a good fan that can move enough air to keep a small Bronco radiator cool. It doesn't matter if it's driven off the belt or driven by the alternator, the load is the same. You won't gain horsepower by going electric.
- Dukietown
Viperwolf1 wrote:It takes horsepower to turn a good fan that can move enough air to keep a small Bronco radiator cool. It doesn't matter if it's driven off the belt or driven by the alternator, the load is the same. You won't gain horsepower by going electric.
Isn't it more of a question of efficiency? Amount of cooling/hp? If it takes more mechanical energy to turn the mechanical fan than it does to generate the electricity needed to make the same amount of cooling from the electric fan then the electric fan wins...
Seems more theoretical than anything, I wonder if you'd feel much of a difference driving down the road.
Seems relevant: http://www.onallcylinders.com/2012/07/2 ... r-vehicle/
