Landsharks 69er Bought not built project
- ZOSO
- Moderator
Re: Landsharks 69er Bought not built project
Chris I'd also suggest some tie down rails mounted to the top of the box. I did that to mine to tie down my cooler and other things I don't want moving around.
- Jesus_man
Just had a thought...I lined my toolbox with some cheap office carpet from a big box store. Helps keep things from sliding around too bad and might prevent things from making so much noise rattling around back there.
- landshark
ZOSO wrote:Chris I'd also suggest some tie down rails mounted to the top of the box. I did that to mine to tie down my cooler and other things I don't want moving around.
I will probably add small d rings on the outside after i install for sure
Jesus_man wrote:Just had a thought...I lined my toolbox with some cheap office carpet from a big box store. Helps keep things from sliding around too bad and might prevent things from making so much noise rattling around back there.
I have 1" thick egg crate foam that I am lining the box with. I will post up once its installed, will be a few weeks until iam ready! thanks for the ideas.
- landshark
So it been a while, finally finished final inspection on my new garage and was able to get prepping the bronco for Mexico. Replaced dash, rewired some of the stuff throughout the bronco. Replaced one side of of the rear axle bearings, replaced front driveshaft and had the rear refreshed. Cut the cup holders off the console and moved it forward to stop hitting my elbow and be able to see the stereo. Rebuilt the steering column and grant horn and replaced the wiring in the column and a bunch of other stuff that needed attention!
Next up, large PS Cooler, braided brake lines and then grill back on
- Rox Crusher
Looking great Chris !
- Kinder
I bet itΓÇÖs nice to have all that room for a change!
- ZOSO
- Moderator
Man that garage is perfect for this now. The 69 looks killer with the fresh paint.
- landshark
Well sheΓÇÖs drivable, will shake it down for the next two weeks and finish the little stuff.
- ZOSO
- Moderator
Only thing missing is some nice beadlock wheels.
- landshark
Ok
- Justin
Best reply ever. Those look sharp!
- Jesus_man
Wow, that's like a
r bet! I'll raise you some beadlocks and new BFG's!
Are those Methods?
r bet! I'll raise you some beadlocks and new BFG's!Are those Methods?
- ZOSO
- Moderator
HELL YES!!!!! Looks killer!!!
cravenbronco
Looks good Chris.
- Rox Crusher
LOoking great Chris !
CanΓÇÖt wait for Baja !
- landshark
Jesus_man wrote:Wow, that's like ar bet! I'll raise you some beadlocks and new BFG's!
Are those Methods?
Yes they are methods.
- Jesus_man
Very interested in what you think if them!
