With the shocks done, I needed to build the mounts for the front shocks and JounceShocks. The Bilsteins were to be mounted in the stock-ish position using F-250 mounts I stole from my last build. (They proved to be too short, but more on that later) The Jounceshocks only had one logical mounting position given the packaging restrictions, which was inside the front coils. To start with, I modified a std FlexMount to bolt to the upper coil bucket and replace the spring retainer.
353 by
J W, on Flickr
Then I needed to modify a lower dome target to sit in the lower coil cup. It seemed straight forward at first until I remembered that the lower coil cup is not flat on the inside. It resulted in me having to carefully cut a roof-shaped peak in the underside and carefully counterboring the mounting bolts and switching to socket-head cap screws to reduce the size of the hole I was making.
352 by
J W, on Flickr
351 by
J W, on Flickr
With those two parts in place, I lowered the truck until the trackbar almost hits the coil bucket and measured the distance between mounts. I needed to add an inch to the assembly to guarantee no impact of the links to the frame. Luckily SPC carries such an extension for this purpose. I just needed to cut and weld it to the right length.
355 by
J W, on Flickr
A quick fitup of the parts
354 by
J W, on Flickr
Then some paint and assembly with anti-seize
356 by
J W, on Flickr
Build Thread:
http://www.coloradoclassicbroncos.com/viewtopic.php?f=3&t=5420Average 23.5 mpg, Best tank: 26.3 mpg
