Finishing touches for Baja. Colorado representing!
Justin wrote:Bronco creep is real. I'll post up once mine is running and let you know how it's looking with a stockish 351w, 4.56 and 37's with the OD. I suspect I'll love it on the flats and shift lots on the hills.
low. But overdrive is great. 2350 at 65mph on 35's is perfect. I'll run it up to the cabin in the next 2 weeks and see how it does pulling the hills. I chose this deep as I plan to do a trailer in the future and the overdrive in the 4r70w is really low. Could have gone 4.88's and been fine. oh and 4low is nuts. first gear is 10mph at 4krpm.
Jesus_man wrote:Can't wait to see it all mounted up! Are you going to try BB's for balancing?
Strike2 wrote:Looks great Mike!
Thanks for posting the picture, I just added a crossbar to my front hoops and now thinking I should install my "Serp" set up and see if the alt/pump assemble will clear the bar before fully welding. I'm sure it wont clear just by looking at your set up, "JUST MORE REWORK"
ZOSO wrote:and coil packs. where are you going to mount those?
Strike2 wrote:Those are cool, are they Ford or Bronco specific? I haven't seen those before.
