Strike2
Post by Strike2 »
Nice looking tires Mike!
I really like the way those steely rims look.
BroncoRaider
Post by BroncoRaider »
I looked everywhere but no matter how hard I tried, I couldnΓÇÖt find blue letter tires....lucky dog.
Post by mickphatmac »
BroncoRaider wrote:I looked everywhere but no matter how hard I tried, I couldnΓÇÖt find blue letter tires....lucky dog.
LOL!!!!
Special order from what I gathered on my Marti Report...Harbor Blue
:laughing2:
Post by Rox Crusher »
Re-fitted / tightened up the fuel tank which was knocked loose by rocks during last wheeling trip.
Got a pretty heavy leak from pinion seal on rear end so gonna have to tackle that real soon
Post by Digger »
Rox Crusher wrote:Re-fitted / tightened up the fuel tank which was knocked loose by rocks during last wheeling trip.
Check the crush sleeve if you still have one. Any pinion movement will eat seals.
Digger wrote:Check the crush sleeve if you still have one. Any pinion movement will eat seals.
I should have done the crush sleeve before going to Baja but crossed my fingers instead...........
Post by Digger »
Well Im only speaking from (bad) experience of squishing the crush sleeve so bad I had to pull the rear driveshaft and tow the camper 150 miles home on the front axle.
I will only build 9's with crush sleeve eliminators from now on.
( In a Steve Urkel voice ) did I do that !!!??? ;)
Helllloooiooo Bronco Hut...
2nd run and now theyΓÇÖre done.
Post by Eck »
We decided to rebel...
BroncoRaider
Fuel efficient is a relative term I guess.
Post by Digger »
Eck wrote:Image
Fight the man!
Technically you're more fuel efficient than a stock Bronco...
been doing a lot lately. Had the engine out and tore down to find the issue with cylinder #3 low compression. Re assembled and installed. Swapped out my old duff headers for new ones to clear the duff long arms. Started the install of those and am still in the process of cutting the larsbars brackets off the frame. Hope to have that finished sunday so I can start to build my exhaust to clear everything.
Solid work Rob! Hope yo get that beast reliable again!
Me...not nearly as much. Tore down a beadlock and replaced a valve stem that had a slow leak. After KOH and getting reports of my folks' wheeling trips near Lake Havasu, really have the itch to go wheeling again!
D&D72
Post by D&D72 »
Duffs installed. Now to find some longer travel shocks.....
Waiting on new u-joints. Old ones are garbage.
...and then thereΓÇÖs the Disc Brake conversion :)
rt9
Post by rt9 »
Finally finished the power steering conversion. All I can say is WOW!ImageImage
Glad someone is doing some work! Good job fellas! I haven't even started mine in...well....a couple months!
Post by Digger »
rt9 wrote:Finally finished the power steering conversion. All I can say is WOW!ImageImage
Is that the Delphi box?
rt9
Post by rt9 »
Yep. Overall was not very hard at all. Just getting time to work on it.
Fired it up again today. This go around was to find the low compression in cyl 3 and advance the cam. Put new headers on it and built my own exhaust. Will get the exhaust finished up tomorrow and start in on the wiring.
Post by Kinder »
[emoji106]
ΓÇ£1stΓÇ¥ I had A problem with this...
ΓÇ£ThenΓÇ¥ I bought this...
ΓÇ£NextΓÇ¥ I finished that...
ΓÇ£*ΓÇ¥ much MO Betta!!!
Strike2
Post by Strike2 »
mickphatmac wrote:ΓÇ£1stΓÇ¥ I had A problem with this...
Very nicely done, having a press make things much easier thumbs up
Post by Digger »
thumbs up
Exhaust is complete. Hope to tie up the rest of the engine stuff tomorrow.
Post by Digger »
That's looking good.
Well I will say damn this thing runs like it should now. Gonna drive it the next few days.
ZOSO wrote:Well I will say damn this thing runs like it should now. Gonna drive it the next few days.
I'll bet that feels good!!
