351 EFI OEM vs NEW
Strike2
Re: 351 EFI OEM vs NEW
Post by Strike2 »
So I've been searching CL for an 96-98 explorer donor and found this a 96 Eddie Bauer isn't she a Beauty !! 230K miles A/T, so the plan is to take all parts needed for the EFI conversion,O2 bungs, serpentine set up, GT40 heads, A/T & cooler, rear disc brakes along with some other odds n ends parts. Anything I'm missing that I should take?
Thanks to everyone on the solid feedback/info as I think I'm heading in the right direction with using the 302 first.
On a side note anyone recognize this greenie substance in pic #3 it sure make the cab smell funny smokin
If you leave the 8.8 whole you can sell it for about 200 bucks to jeep guys.
Strike2
Post by Strike2 »
ZOSO wrote:If you leave the 8.8 whole you can sell it for about 200 bucks to jeep guys.
Thanks for the info on the 8.8, 6 months ago the guy just had Brakes Plus replace the back rotors/hardware + oil change for 366.56! Tomorrow I will start removing parts and if the rear disc's look good I'm going to use them to convert the 9" to disc.
sykanr0ng
Post by sykanr0ng »
$200 is at the low end of what the Jeepers will pay, depends on gearing and whether it has any traction device in it, it could go $300.
Hang on to the block, a roller builder is worth something too.
Strike2
Post by Strike2 »
2 days of working in the garage and I think I have all the parts needed for the 302 conversion. All in all it when pretty smooth the only real issue was removing the manifold as 2 of the front bolts snapped off leaving 1 bolt in each side of the GT40 head's, on a side note it had the bigger 1/2" hole's thumbs up . I will just let Western Motors remove them. I'm glad I didn't go about getting all these parts at a JY as I used just about ever tool in my arsenal! removing the headers sure was interesting as the tubing is crimped everywhere from the factory to get them to fit.
I will spend the next few week cleaning, sandblasting all the parts getting them ready for this spring.
Thanks again for everyone input on this as I think I'm heading in the right direction.
Post by Rox Crusher »
I understand those Eddie Bauer trim pieces bring good money too
