302 removal
crawlercreations
Re: 302 removal
Post by crawlercreations »
Backcountryrenegade wrote:Ok what am I missing? These brackets donΓÇÖt line up with the adapter for the alternator. I figured out the power steering relocation but the alternator not so much. ImageImage
Your alternator bracket is the oddball bracket that was used with a power steering pump above it. Common on early power steering conversions. To make the adapter work you need a set of stock alternator brackets.
Backcountryrenegade
Re: 302 removal
Post by Backcountryrenegade »
ItΓÇÖs stamped Ford? Interesting. Mine is a 75- thought it came with power steering?
Will that change the belt I use?
Re: 302 removal
Post by Viperwolf1 »
Thermactor pump not ps pump.
Re: 302 removal
Post by Kinder »
I may have a old stock alternator bracket setup, IΓÇÖll look when I get home.
Backcountryrenegade
Re: 302 removal
Anybody have thoughts on changing out the torque converter? WhatΓÇÖs a good one to use? Mostly driver, towing some.
Re: 302 removal
Stock converter would be fine with the torque of a 351.
Backcountryrenegade
Re: 302 removal
Crank moved when I bought motor. Been inside sitting for a month. Went to turn crank- wonΓÇÖt budge. No plugs installed. WTH??
Backcountryrenegade
Re: 302 removal
Got it to move- panic attack there.
