74 Baja Race Bronco - Baja or Bust
- rt9
Re: 74 Baja Race Bronco - Baja or Bust
In the spirit of Chris's build, and for those that get the Elrey network on DirecTv, they have the 50th Anniversary Baja 500 Sunday at 6pm.
- landshark
Finished working on most of the frame, cutting off what I donΓÇÖt need, track bar drop bracket, stock shock mounts etc. turned out the stock track bar bracket was junk so cut that off too and used a heavy duty drop bracket I had laying around and fabbed up a new one.
Re-enforced some spots on the frame, leaf spring hangers, radius arm frame mounts, both sides of the frame where the steering box mounts and a few other spots. Threw a quick coat of paint on it.
Mounted the rear springs, axle is under it but still have to cut out some of the back brace to make room for the spring perch and u bolts and burn in the rear brake brackets.
Working on the Dana44, should have it rebuilt tomorrow and hopefully get it mounted under the frame manãna.
- Strike2
Nice progress its looking good
- Jesus_man
Sure makes it a lot easier to hang that stuff onto a bare frame! Or at least, that is my assumption as I've never had that luxury!
Those lift blocks are saaaweeet!!
- landshark
Front end is rebuilt and re-geared and then slid it under the frame. Welded the front and rear lower shock mounts, started running fuel, brake and transmission cooling lines.
- Jesus_man
Whose leaf spring plate is that? I feel like I have some issues with mine, even tho they are extra thick...
- landshark
Jesus_man wrote:Whose leaf spring plate is that? I feel like I have some issues with mine, even tho they are extra thick...
Ruff stuff, i run one on my 69 without any issues the last few years. I welded the spring perches on them as they come as just a plate.
- Jesus_man
landshark wrote:Ruff stuff, i run one on my 69 without any issues the last few years. I welded the spring perches on them as they come as just a plate.
Thanks! I need to take a closer look at my setup. Seems after a couple trips, I get a vibration and last time it was due to loose u-bolts and the axle wasn't parallel to the frame.
- landshark
Jesus_man wrote:landshark wrote:Ruff stuff, i run one on my 69 without any issues the last few years. I welded the spring perches on them as they come as just a plate.
I meant Shock mounts, not spring perches.. lol
- landshark
i'll just leave these here.
- Eck
Schwwwwweeeetttt!!
pgilbeau
Nice! Did you build or have built?
- ZOSO
- Moderator
Im curious to see the build sheet. So when do I pick it up.
- landshark
pgilbeau wrote:Nice! Did you build or have built?
Had it built.
- landshark
ZOSO wrote:Im curious to see the build sheet. So when do I pick it up.
Me too! ItΓÇÖs probably ready to be picked up as they pulled it right after that run today. I need a cherry picker to get it out of your pickup.
- Rox Crusher
I have a cherry picker you can borrow
- ZOSO
- Moderator
landshark wrote:ZOSO wrote:Im curious to see the build sheet. So when do I pick it up.
I have both. I'm not in town this weekend but could possibly help one afternoon next week.
- Strike2
That going to a great sounding Bronco!
In the pioneer class other than no EFI is their a limit to the motor size/hp?
- landshark
ZOSO wrote:landshark wrote:ZOSO wrote:Im curious to see the build sheet. So when do I pick it up.
Ok I might need to sneak up there and grab that engine before next week as I will be out wed to fri next week then Monday to Thur the following.
- landshark
Strike2 wrote:That going to a great sounding Bronco!
Technically it doesnΓÇÖt say you canΓÇÖt have EFI and I explored that option but the racers can point and cry foul so I am trying to stay true to the spirit of the class and stay in their good graces.
No size or power limit.
- Jesus_man
Did you get to witness the dyno run? What were the numbers? I saw some some mid 400's!!
- landshark
Jesus_man wrote:Did you get to witness the dyno run? What were the numbers? I saw some some mid 400's!!
Yes I was there for it. I will say my request to put 400/400 to the ground will be met :)
- Jesus_man
landshark wrote:Yes I was there for it. I will say my request to put 400/400 to the ground will be met :)
You can't let the competition know any racing secrets!!
- Eck
Let me know if you need a hand getting the engine.
- landshark
More stuff on the frame, engine home, viper built transmission and transfer case in temporarily.
- landshark
Forgot I started to weigh stuff.
Will weigh the transfer case and transmission when I pull it again. Need to weigh the leveler to subtract it from the transmission.
Will also weigh both ends of the bronco once I have a few more things on it.
- Strike2
Man you are in Hyper-drive!!!! you almost have a roller its looking great
- Jesus_man
Wow, so clean!!
- sykanr0ng
On the other forum you said you shaved the 9 inch, do you have any pics of that?
TIA
TIA
- landshark
sykanr0ng wrote:On the other forum you said you shaved the 9 inch, do you have any pics of that?
TIA
Jason (crawlercreations) actually shaved and plated it as this was his axle. I don't think i have any pics but will take one tonight for ya.
