project viperwolfe is starting
- D&D72
Re: project viperwolfe is starting
Rox, you can take glass off the list.
- Gregg
Rox Crusher wrote:BroncoRaider wrote:I'm available for a couple of days. Let me know place & time.
-Tim
The current plan is to start on Saturday Nov 21 and work through the following Sunday.
Excluding bird day of course.
I pm'd my address to you. Trying to not post it publicly cause that pink zip tie character or his brother from another mother might show up.
I think he lives somewhere on A$$hole Lane. And don't worry, I'll bring Yo Yo's with my Bro Bros.
- Rox Crusher
D&D72 wrote:Rox, you can take glass off the list.
Phil is the list meister
Thanks so much to you and Greg Evans for getting the smoked glass put together !
- Viperwolf1
Updated list.
[ ] Carpet
[x] Adjustable trackbar
[x] Grill pieces
[x] Striker posts
[x] PS reservoir
[ ] Gas filler screws
[x] Driver door window tray
[x] 6 screws for window regulator
[x] 4 bolts for window track
[x] Lag bolts for arm rests
[ ] Driver door rod to outside handle
[x] Bump stops
[ ] Bumpers
[ ] Wheels/tires
[x] 4.56 or 4.88 gears
[ ] Soft top
[x] Rebuild 44
[ ] Exhaust
[x] Glass
[ ] Carpet
[x] Grill pieces
[x] Striker posts
[x] PS reservoir
[x] Bump stops
[ ] Bumpers
[ ] Wheels/tires
[ ] Soft top
[x] Rebuild 44
[ ] Exhaust
[x] Glass
- Viperwolf1
I fixed my radio hole and made my shift knobs.
Oh, there's that spare turbo.
Broncobsession
Did you/Jeff get the spindle I sent?
- Rox Crusher
Broncobsession wrote:Did you/Jeff get the spindle I sent?
Yes indeedy, just found it last week.
I rarely check my mailbox so I don't know how long it's been there.
Thank you very much for sending it !
- colby45
I got here long after this project started, but I'd like to jump in and I can lend a hand that week of Thanksgiving. Just let me know when and where.
Sally
'66 Halfcab
'66 Halfcab
- Rox Crusher
colby45 wrote:I got here long after this project started, but I'd like to jump in and I can lend a hand that week of Thanksgiving. Just let me know when and where.
That would be awesome !
PM with my address on its way
- casadejohnson
I'm going to try to be helpful when thanksgiving week rolls around if work doesn't get in the way. Phil, when I brought the Block down I also brought some doors down, were there not rods for the drivers side door locks in there? If not I might have some of the parts from those doors in one of my many boxes of Bronco parts.
- Viperwolf1
casadejohnson wrote:I'm going to try to be helpful when thanksgiving week rolls around if work doesn't get in the way. Phil, when I brought the Block down I also brought some doors down, were there not rods for the drivers side door locks in there? If not I might have some of the parts from those doors in one of my many boxes of Bronco parts.
Might be. Those doors are still at MIke G's house. I need to pick them up.
- casadejohnson
Viperwolf1 wrote:casadejohnson wrote:I'm going to try to be helpful when thanksgiving week rolls around if work doesn't get in the way. Phil, when I brought the Block down I also brought some doors down, were there not rods for the drivers side door locks in there? If not I might have some of the parts from those doors in one of my many boxes of Bronco parts.
Sounds good, hopefully the rod you need is there. If its not, I'm happy to go through my pile of hoarded parts
- landshark
where did you get the fuel filler door neck thingy?
- Viperwolf1
landshark wrote:where did you get the fuel filler door neck thingy?
http://fuelsafe.com/store/fill-accessor ... l-882.html
- ZOSO
- Moderator
So what is the full schedule over the next 2 weekends?
- TOOLMAN
ZOSO wrote:So what is the full schedule over the next 2 weekends?
I would like to know as well. I would like to stop by to help, but I may have a gnarly work deadline the week of Thanksgiving.
- Rox Crusher
We'll get it posted up over the next couple of days.
I think we are going to get a late start this Saturday as Phil might be attending the breakfast.
I have to help a neighbor move and should be home by 10 am or so. We can start anytime after that.
- Eck
I plan to come over during the week next week as I have taken the week off. Shoot me a PM with your address and let me know when you plan to get going each day.
- Rox Crusher
Ok, we will probably get started a little late today due to road conditions etc
Come on over after the breakfast. Garage will be heated and there will be coffee to help keep warm.
Today's projects will include finishing installation of the D44 front axle and re-gearing the rear axle from 4.11 to 4.88. Plenty to do if you can make it !
- Rox Crusher
We got the front end swapped and built a TRO steering linkage set up.
Had some trouble drilling out the pitman arm so we are on the hunt for a replacement and a place with a real drill press.
We will be back at it today with a 9 am start time.
Probably going to work on re-gearing the rear end and maybe exhaust system.
- Kinder
I'll check my stash for a pitman arm, I'll let you know if I find one and bring it with me this am.
- Rox Crusher
kinder wrote:I'll check my stash for a pitman arm, I'll let you know if I find one and bring it with me this am.
That would be great...........he needs a relatively flat one.
You lent me one previously which I very much appreciate.
- Justin
I've got the drill press. If the pitman is anywhere near me I can pick it up, drill it and deliver.
- landshark
i might have a stock extra pitman arm
- hockeydad4-22
Are there any plans to work on it over this weekend? I should have some free time and I have some glass samples I need to bring over for Phil to check as well.
- Viperwolf1
The work never ends.
- EFI Guy
- VENDOR
I'm going to try and make an appearance this weekend if that's the case. You guys wrenching both Saturday and Sunday?
- casadejohnson
I found out that I'm working Friday now so I'm looking at the weekend as well. Jeff, Message me your address, I had it in my previous phone but it seems to have not transferred to my new one.
- Rox Crusher
We are working today, Friday, Saturday, and Sunday. We generally start between 8 and 9 and wrap it up around dinner time.
Today will be kind of a thrash as we need to finish installation of ARB in the rear, install exhaust, and install twin sticks and fool around with transfer case mount.
Friday, Saturday, and Sunday will be mostly dedicated to body work and getting it primered.
Stop by any time. I really appreciate knowing who is coming and when so we don't mistakenly run off on errands with the joint all locked up.
Thanks to everyone who has already helped this week and looking forward to seeing others over the next few days.
- Rox Crusher
Thank you Kirk, it worked beautifully !
Justin, the pitman arm we boogered up is available for your welding art projects if you want it.
