Justin's retroactive build thread
- Eck
Re: Justin's retroactive build thread
Thumbs up !
- Rox Crusher
That's awesome !
- Gunnibronco
I'm jealous.
- landshark
The question is did it get back into the garage.
Nice job lets go wheeling!
- Jesus_man
Congrats!! I hope to get to see it work offroad someday!
- ZOSO
- Moderator
Sweet!!! about time for a simple axle swap and long arms.....
- TOOLMAN
Very nice!!
- akaFrankCastle
landshark wrote:The question is did it get back into the garage.
Yes. Very suspicious how the video only shows him leaving, not coming back. Hmmm.
- Justin
Thanks guys! I can assure you that I did return and without any parts falling off. Which was good, because I wasn't sure that would happen. The front suspension needs some spring preload adjustment and may need longer or stiffer springs. The front end is currently sitting about 2" lower than the rear and it's almost riding on the bump stops. An alignment is also badly needed, as the toe is way off. Hopefully that all that and the front bumper mounting can get done this week so I can make the drive to the springs.
- Eck
I've got my old springs still. They were fairly stiff if you'd like to try them.
- Justin
I appreciate the offer, but with the switch to coilovers they won't fit. The good news (and part of why I wanted to go with coilovers) is that used springs are about $25 each on ebay.
- Zenzone
It's looking so good! I can't wait to see it crawl this summer!!
- rt9
Nice job! [emoji106]
- Colorado75bronc
Looks awesome Justin! Congrats! I wish I didn't have to work this Saturday so I could see it! :(
- Justin
Thanks! Still not 100% that I'll be there. Tore the front end apart again for alignment, spring adjustment and to shorten the throw on the bump stops. Need to remount the bumper too.
- Justin
Had to post up some welding porn. Found this very tidy TIG weld inside my bump stops. Someone at Fox has very steady hands, or a very expensive robot. Either way it's pretty.
- Digger
That's a winner there!
- Justin
Got a call from Scott that my block is done. Only had to be bored .020 over, which was surprising given how bad the cylinders looked.
- Viperwolf1
Was this the U-boat engine?
- Justin
After it sank, maybe. Lots of rust. I guess there's some staining on the #7 cylinder, but it's serviceable.
- Justin
Picked up the block and build kit today. Can post pics later. Have to say, I'm pretty happy with the parts. It's all USA made stuff. Quick question: For our uses, how do the following cam specs look? RPM range seems perfect.
Advertised Duration Duration @ 0.050" Valve Lift Lobe Basic
Company Part Number Intake Exhaust Intake Exhaust Intake Exhaust Center RPM
Cam Research CR266 266┬░ 266┬░ 210┬░ 210┬░ 0.410'' 0.410'' 109┬░ 1,000 ΓÇô 4,000
- Viperwolf1
Similar power to an Edelbrock performer cam. Lobe separation is a little low for EFI.
- Justin
How much more would I get out of a different grind? I'll be using and edelbrock intake and gt40 heads.
- ZOSO
- Moderator
lift seems low for that duration. for efi you want lsa to be closer to 114. 210@.050 is good torque. you can even go up to 212@.050 and get the lift up in the 460 range.
I assume this is a flat tappet cam?
- Justin
Yes, flat tappet. Had planned to go roller, but couldn't turn down a free block.
- Justin
Finally some time to post up about the Bill Moore run. Overall, went well, and ended up being a great day with an old friend of mine that had flown in from Seattle and a Mazda club buddy that bought a Jeep awhile back. Truck performed great, and uncovered some areas that need a little work. My rear ARB is leaking air badly. Should have replaced the seals while the axle was apart, but it's not the end of the world. Front end still needs to be a little higher to keep it off the bump stops, but that wasn't a surprise either. The major bummer was sliding off the trail while busting through a 2-3' snow drift against a tree and mashing up my passenger's door and a spot on the front fender. It'll need a skin and some paint, but the window closes and the door alignment wasn't affected, so it's just cosmetic. Also ran up to the top of Mt. Evans (where I got appreciative comments from hot wimmins
) and over Guanella pass. Ended up being 193 miles of fun!
) and over Guanella pass. Ended up being 193 miles of fun!You do not have the required permissions to view the files attached to this post.
- Justin
Picked up the block and build kit today. Pretty happy with how it came out overall, as it only needed to be bored over .020. There's a little staining in the #7 cylinder. I'm really happy with the build kit Scott supplied as it's all Made in USA parts from major brands. Scott was also able to rebalance my harmonic balancer for less than Damper Dudes charges, so that was convenient. Next I need to figure out if I'm going to have my GT40 heads milled down. It'll depend on whether I can find someone who charges (way) less than MPG and still does a good job.
Also, can anyone tell me what the hole in the block just above the front-most lifter bore is for? It's in the last pic.
- Viperwolf1
That's an oil drain hole.
You won't find many flat tappet cams with 114 lobe separation. You can find some that give better low end torque than the CR266 though which is probably what you want. Here is a comparison between the CR266 and Comp X4254H. It's only 111 degrees lobe separation but it give a good torque increase under 3700 rpm.
- Eck
I've heard Colorado Custom Cylinder Shop does good work at a reasonable price. Might be worth a call...
- Digger
Your trip to Mt. Evans looked awesome.
