- Justin
Got the new column in. It's a tad too short, but it'll work fine. Tomorrow, the lower steering shaft and steering wheel go back on.
socofn
Headed out to start the front disc brakes after picking up the spindles and hubs from Shane. Wish me luck. Jayson
74, MONEY EATER
- Rox Crusher
installed some new to me armrests (THANK YOU 76ford)
installed some nifty wing window locks (THANKS AGAIN 76ford)
continuing to clean the 5.0 up for paint, etc
wondering what to do with the intakes.................maybe blast and clear coat ?............maybe polish...............maybe just clean up real good
any ideas / suggestions ?
- Entourage
Installed a free window sticker from Wild Horses. They also sent me a cool t-shirt. Surprising what you can get thrown in when you cry uncontrollably on the phone about the cost of new 31 Spline HD axles
No surprise, the axles, bearings, bushings, and retainers that Jim recommended fit perfectly.
- airbur
Wow...what else did you get for free? You are a rolling billboard sign for them now!
- Jesus_man
Unspooled my winch and put a new end on the line so I can respool it and hope it holds the weight. I need to source some sticky back rubber strap to spool on the drum first to help the cable bite.
- Entourage
airbur wrote:Wow...what else did you get for free? You are a rolling billboard sign for them now!
I have only got the sticker and t-shirt for free on my last order but crying to another man cost me my dignity
I wanted to try the Window Sticker out for research for CCB Club Window Stickers to see the size, height, width, font, and if the stickers should stick on the inside or the outside of the window. This one sticks on the inside and I definitely prefer them to stick on the outside since I have a few bubbles.
I think the sticker looks like that is the name of my truck instead of advertising for WH. Kinda makes my truck look like a boat lol. I would suggest they add 4X4.com to the end of the sticker.
I definitely don't notice the sticker inside while driving with it mounted at the bottom of the window. I won't be a Billboard (or boat lol) for long - hoping to make some progress on the CCB window stickers in time for the August Breakfast.
75DBE
So from a MUCH earlier post -- "Today she gets all of the unnecessary mechanical equipment taken off from under the hood." I assume that means the smog / emissions control piping and the air pump, etc.?
- Moab Mike
75DBE wrote:So from a MUCH earlier post -- "Today she gets all of the unnecessary mechanical equipment taken off from under the hood." I assume that means the smog / emissions control piping and the air pump, etc.?
I have no knowledge prior to the trial your honor!
- Moab Mike
I saw swiegum turning onto C470 from Bowles at 4:22 PM. SURE LOOKS SHARP!!!!!
- 66and70Broncos
Drove to work and someone had a truck and 35 foot trailer in front of where I park...no problem...over the curb I went to get around it. Stopped by Advance as my blinker switch had gotten water in it...replaced it for free...now Ive weatherproofed the switch to avoid the same thing happening.
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Life is 10% what happens to you, and 90% how you react to it.
New EB 1970 V-8 302
Next EB ? 5.0 EFI
- Badlands
76fordbronco wrote:I saw swiegum turning onto C470 from Bowles at 4:22 PM. SURE LOOKS SHARP!!!!!
Haha! Thanks. Those new tires are sweet!!
Got her licensed today, cleaned up my carb and replaced the fuel filter. Running pretty strong for a straight six! :) Also ordered cables for the parking brake.
Need to get the dang driver side door closing better, that brake done and seat done.
- hockeydad4-22
Drove it to and from work yesterday and today - and taking it camping and wheeling this weekend!
So there!
So there!
- Jesus_man
Had to break the news to mine that she wasn't going camping with us this weekend... :(
But I plugged her into the battery tender to keep her young and fresh!
WestMuddy
Performed last night:
Connected header pipes and new mufflers up;
Finished cover over NP435 tranny (tranny still on shop floor 'cause of the lack of tranny-to-xfer adapter);
Filled new (to this buggy) Dana 44 axle, tired 3 speed tranny, xfer case, old 9" ford rear axle;
Put cotter pins in new tie rod assembly;
Reconnected engine (carberator, heater, etc);
Reinstalled, cleaned up and filled battery;
Inspected new (to this buggy) front disk brakes;
Tried to start it and ended by scratching my head over why it wasn't pulling fuel out of the tank.
75DBE
Took out the frozen 302 and started prepping the Donor 302 for install! Craziness.
- akaFrankCastle
Didn't really do anything to MY Bronco today, but...
I did buy a tub.
I did buy a tub.
- ZOSO
- Moderator
I knew that wouldnt last long. You just couldnt wait to get it all perfect huh?
- Jesus_man
akaFrankCastle wrote:I did buy a tub.
So it looked pretty solid eh?
- akaFrankCastle
Jesus_man wrote:akaFrankCastle wrote:I did buy a tub.
Floor pans and one of the inner fender to kick panel joints will need patching. Aside from that a few small dents and scratches. Pretty solid overall. Will make a good temp tub until Val and I get his current tub polished up. Definitely not what I would consider trailer material.
The girl who sold me the tub also has a few more parts available as well. Hard top, windshield frame, front fenders, hood, other misc stuff.
And for you Mustang junkies, her BF has about a dozen 60's Mustangs that he is parting out. Let me know if you need contact info.
75DBE
Certainly what I need to look at next -- after the engine. My doors sag a bit (passenger worse than driver) and are hard to close and I've got what I am told are "normal" rust spots inside the engine compartment right where the inner fender meets the firewall.
- ZOSO
- Moderator
Got the driver side floor pan cut out. Got the new one fitted. Will weld it in tomorrow and work on a few other patches. Gonna order up some flairs and start cutting fenders.
- airbur
I finished reviving the last big panel....the tailgate today. Only things left are the window and windshield frames:)
- akaFrankCastle
Started tearing my dash out to troubleshoot my no-start issue/possible prep for a new wiring harness. I hate Ford at the moment. Those stupid 7 screws in the dash panel from under the windshield frame added about 30 more minutes on to the job than I wanted.
- Justin
Finally finished painting the bumper and got it mounted up. Now to find a spare!
- Rox Crusher
finally eliminated the alternator belt squeal
I suppose the belt will stretch some more over the next few weeks and it will return
- airbur
Finished polishing yesterday. Looks like a different truck:). Going to uninstall the tach today and see if Advance will warranty it.
- ZOSO
- Moderator
Got the drivers side floor pan all cut out and the new one screwed in. Ready to be welded. Was just too damn hot outside to be welding. I really need a bigger garage. Was gonna order up my flairs so I cn start cutting fenders before I start prep for paint.
- Rox Crusher
airbur wrote:Finished polishing yesterday. Looks like a different truck:). Going to uninstall the tach today and see if Advance will warranty it.
If this were me I would be telling my wife that I deserve a few upgrades with all the money saved by not needing a paint job
- airbur
I think it's the other way around since I spent so much time on it! She's asking what she gets to do for an entire weekend now:)
