Black Smoke Donkey
millerpz
Re: Black Smoke Donkey
Oh and I have an 89 (same as a 91) if measuring one would help.
- Kinder
- Kinder
Digger wrote:Kinder wrote:Housing is toast. I know itΓÇÖs a long shot but if anyone has a lead on a 1978-1979 D60 housing or complete axle let me know.
Dang. Is the center section messed up?
I missed this, yes, he (they) said the center section was also bent.
IΓÇÖve got a tip on another complete axle, IΓÇÖll post up if I get my hands on it.
- BroncoCrawler
- Kinder
BroncoCrawler wrote:https://www.facebook.com/groups/rockcrawlingclassifieds/permalink/2303956119839334/?sale_post_id=2303956119839334
Sent from my Pixel 3 XL using Tapatalk
Private Group, something there worth joining for?
- BroncoCrawler
It's ok just depends how bad you need one.
- Kinder
Thanks for keeping an eye out for me, that price is actually good. VA would be tricky, but I do know a guy that hauls equipment from the east coast through Denver.
- Kinder
- Jesus_man
Thumbs up!!!!
- Rox Crusher
Now weΓÇÖre talking !
- Digger
Back in business. Alright !
- Kinder
The box grader at the park needed some repairs, BSD with the onboard welder to the rescue.
- Digger
*two
That beast is a true workhorse.
- Rox Crusher
Park team: stand back here comes Clint Eastwood / Chuck Norris / Macgyver again
- D&D72
Rox Crusher wrote:Park team: stand back here comes Clint Eastwood / Chuck Norris / Macgyver again
What about red/green?
- Kinder
Black Smoke Donkey
It had a good run, but the day has come, turbo rebuild time. IΓÇÖve always wondered what turbo was on my 4BT, itΓÇÖs a Holset HX30. Based on what IΓÇÖve read from others itΓÇÖs one of the better turbos for the 4BT, and itΓÇÖs performed well for me. IΓÇÖm going to attempt rebuilding it myself, kits arenΓÇÖt that expensive and the turbo is internally balanced. If I canΓÇÖt sort it IΓÇÖll look for a local shop before sending it out. I think I caught it before any damage was done, fingers crossed.
- Jesus_man
Do they offer upgraded impellers?
- crawlercreations
Turbo rebuilds are easy peasy. My first was the stock turbo on my 7.3 bus. Installed a wicked wheel 2 at the same time. Nothing to it.
- Kinder
Jesus_man wrote:Do they offer upgraded impellers?
There isnΓÇÖt much out there for the HX30, most upgrades are oriented to the HX35 for the 6BTs. The HX30 can push 35 psi if given the fuel. My performance improvements live in the P Pump, I plan on upping my governor spring to 3k and swap in a new #10 fuel plate. ThatΓÇÖs about as far as I can go until I swap in heavier valve springs and fire ring / stud the block.
- Kinder
crawlercreations wrote:Turbo rebuilds are easy peasy. My first was the stock turbo on my 7.3 bus. Installed a wicked wheel 2 at the same time. Nothing to it.
Thanks for the encouragement, I ordered the rebuild kit and watched a couple of vids & downloaded the service manual and spec sheet from Holset. I started the tear down last night. I just need to remove the exhaust housing, it doesnΓÇÖt want to come off easy, of course itΓÇÖs seen 1000 degrees hundreds of times, IΓÇÖll hit it a little harder tonight.
- Error404
I would like to find an hx30 for mine. I have an hx35.. i have a wicked wheel in my tool box and stage 1 fuel pin and a stage 2 stashed for later.. lag is pretty bad. Currently get to 26lbs...but my head gasket finally gave up.
1996 bronco 4bt sas .
1972 bronco 10k mi no motor no trans..unfortunately rolled in 1973. Left for me to bring back from the dead.
- Kinder
From what IΓÇÖve read the HX30 is one of the best turbo matches for the 4BT, also the head gasket on the 4/6BTs is definitely a weak spot. The future hold pump upgrades for me, gov & fuel plate.
Error404 wrote:I would like to find an hx30 for mine. I have an hx35.. i have a wicked wheel in my tool box and stage 1 fuel pin and a stage 2 stashed for later.. lag is pretty bad. Currently get to 26lbs...but my head gasket finally gave up.
- Kinder
BSD is back on the road, that took way too long. The rebuild kit was only available from one place online, I guess the HX30 isnΓÇÖt all that common. IΓÇÖll break it in easy then hammer it to make sure all is well. Pics tomorrow to prove it runs!
- Kinder
- landshark
Kinder wrote:A little late, proof that itΓÇÖs back in the wild.
That photo could have been taken at anytime... where is the newspaper with the current date???
- Jesus_man
Either way, all I know is I am jealous of you getting out into the mtns! Was home for a few days last week and did some light wheeling with my Dad in his Rubi. It was great to be in paradise!!
- rt9
Was at the car show in Elizabeth this weekend. A guy was there going on and on about this cool stretch bronco he saw in Parker. He was absolutely in love with it. LolKinder wrote:A little late, proof that itΓÇÖs back in the wild.
- Kinder
Newspaper? How old are you, ha! IΓÇÖm in the park at the new trail that IΓÇÖve been working for forever. TodayΓÇÖs work is a bench install and buck & post/rail fencing.
- Digger
Any updates?
How's she running? Do I need to tune up the 2.8 to hang with you?
- Error404
Have you done headgaskets/studs in the 4bt yet?
