TJ's 74 Bronco money pit
cpldavis37
Re: TJ's 74 Bronco money pit
Post by cpldavis37 »
351, it's gonna be a copy of Phil's with aluminum heads.
TJ
F. Scott Fitzgerald
cpldavis37
I picked this up today in Milliken. The guy bought it 8 years ago but never mounted it he said it came from a guy who was down by Chatfield. Anyone recognize it?
TJ
F. Scott Fitzgerald
Post by mickphatmac »
That's a cool looking hood, I've never seen one like that before. Nice score!
Never seen one like that either!
cpldavis37
Air craft stripper. 2 applications.
TJ
F. Scott Fitzgerald
You said stripper.....
Post by Kinder »
Wow, that stuff is no joke, I bet the storm drain is running good.
cpldavis37
Well I screwed up somewhere and had to strip it all over again. I don't think I let the primer dry for long enough.
TJ
F. Scott Fitzgerald
cpldavis37
I think that the original powder blue paint is the strongest substance known to man. That paint eats aircraft stripper and shits wire wheels.
TJ
F. Scott Fitzgerald
Post by Rox Crusher »
cpldavis37 wrote:I think that the original powder blue paint is the strongest substance known to man. That paint eats aircraft stripper and shits wire wheels.
Must be similar to the grey paint Ford used on the oil pan on mine.
I wonder if that naval jelly / stripper left a residue that the primer doesn't like ?
cpldavis37
I thought about that, but I pressure washed it for 20 minutes. You could be right though so I'll use mineral spirits or something like that before painting.
TJ
F. Scott Fitzgerald
Post by Gunnibronco »
Rinsing the stripper with water should have been ok. I would expect stripper to maybe hide in the nooks, crannies, and seams and maybe show up there, but not in the middle of a rinsed panel. What kind of primer? Rattle can or spray gun?
cpldavis37
Rattle can.
TJ
F. Scott Fitzgerald
I'd guess it wasn't cured. I'd strip it all again, unfortunately.
Mist some etch prime on the bare metal, & reprime. I wouldn't use a 'high build' or 'sandable' primer, just regular primer. One, maybe 2 coats. Then blast with color.
We have had bad luck with rattle can high build/sandable primers at the shop.
cpldavis37
I will try it thanks.
TJ
F. Scott Fitzgerald
cpldavis37
Welding is harder than it looks :Welding:
TJ
F. Scott Fitzgerald
cpldavis37
Looks better in primer. I did a lot more prep this time around and it came out nice.
TJ
F. Scott Fitzgerald
cpldavis37
Update.
TJ
F. Scott Fitzgerald
Looks great!
Coming along! I'm about 50 lbs of wire into my welding career and have only been getting really nice welds in the past year or so. Making a strong weld isn't super hard, but making a pretty one can be.
cpldavis37
I decided to bed liner the Bronco. Here are some before and after pictures.
TJ
F. Scott Fitzgerald
Looks good! Which liner did you use?
BroncoRaider
Post by BroncoRaider »
That looks great! I'm looking forward to that myself.
cpldavis37
I used duplicolor bed armor, but I sprayed it with a gun. I wire wheeled the whole thing first then washed with soap and water. It came out looking nice.
TJ
F. Scott Fitzgerald
Engine bay and Bed turned out really, Really nice!
Keep the pictures coming!
Good job man!
That looks great !
cpldavis37
What have I done to myself?
TJ
F. Scott Fitzgerald
Post by Kinder »
Wiring is fun!
cpldavis37 wrote:What have I done to myself?
I keep asking myself the same thing.
Hey, you know, while it's apart, it would be a good time to..............
both of these are SO TRUE!!!!!!
