Project "Wilma" 1971 Bronco
Re: Project "Wilma" 1971 Bronco
Post by Kinder »
Well if I happen to c 1 I'll chk with you b4 I pull it.
Post by hockeydad4-22 »
Front springs in...... check
For the first time since I have owned her, Wilma is a roller!
Next step, start mocking up the drivetrain, engine, trans and t-case (which I am still looking for btw), then start in on the tub.
But first, chain her to the column in the garage before Drew, Frankie and Willem get any bright (jackass) ideas and test my insurance coverage
have I mentioned how awesome this club is?
Today a member called me as he was in the neighborhood with a special gift for me.... He had picked up a NP205 and delivered it to me and ge got it at an absolute deal! Thanks !
So in addition to attending several graduations, partys and dinners, I managed to spend sometime in my garage this weekend. I took most of a day and got about half the engine cleaned up, then I recruited several big strong teenage boys and one big strong bronco brother and we carried Wilma's tub out of the back yard this morning and placed her on the frame.
After that we rolled hr back into the garage so I could go spend some time at said Bronco Brothes house helping him with his project.
I know...pictures.....
So once Wilma's tub was applied to her frame I was able to get my first good look at what it is I am working with
I've been spending half a day per weekend over the last several weeks going through the engine, taking it apart, cleaning, painting, replacing seals and putting her back together.
Just about done with the top, need to pull the valve cover and replace the gasket, I think that is the only leak I have on he whole thing. Then I will drop the pan, replace the rear mail seal, pan gasket and prob he pump as well.
With half an ounce of luck, by the weekend this part of the project will be done. Then on to trans, t case and getting all of them between the frame rails so I can start body work
Very nice! Between Wilma and the Black Smoke Donkey, we're going to have some unusual rigs in this club.
I scored some 5 1/2" leafs and progressive coils from Kinder - so once again, Wilma has grown....
Definitely need to do some extended radius arms now!
Does not look like much with no body work done (have to fill my welding gas so I can get after it- been carrying the empty in my truck for about 2 weeks - just have not gotten over to ft it filled) so I did not take any pics
Oh boy - this has been far to long with out updates - mostly because there have been none to give.
I gave my engine, steering box and T-case to Drew to get his bronco running and driving reliably, then he decided he wanted my axles - which he removed but never installed in his - just tore down and left them, my suspension and all the hardware scattered all over the garage. At that point I decided it was best for me to leave Wilma alone for a bit while I worked on his. Which I did, as well as working on both son's other trucks at seemingly regular intervals (is it just me or does there seem to be a pattern here?)
Well last Tuesday I finally made it up to Pine Junction to pick up a brand new to me set of rollers (Thanks Colby!) and that got me all fired up to get back to work. So this weekend I put my rear axle back together, mounted those rollers to both axles and started to re-assemble the front suspension. This was halted suddenly when I realized that 6 of the 8 bolts for holding the C-Caps to the radius arms are missing... Fortunately while I happened to be cruising the Littleton PnP on Saturday (yeah - I know, its a strange way to spend a Saturday afternoon - what can I say? I'm a strange guy) I noticed a 78 bronco there that still had the front axle installed. Therefore today - after work - I am off to snag those elusive bolts.
Once I have the axles back underneath - other than the drive train parts that are missing, I am where we left off what - 2 years ago or so.
Picks when there is something worth posting.
If PnP doesn't yield some bolts I think I've got a few spares laying around.
I was thinking about Wilma the other day. Glad the ole girl is getting some attention!
colby45
Post by colby45 »
Glad you could make use of Sally's old wheels for Wilma. Thanks for making the long trek to Pine Junction to grab them!
Sally
'66 Halfcab
Post by Kinder »
Let me know what parts you need, I'm STILL cleaning out my garage and side yard junkyard.
Thanks to bronco brothers Phil, Kirk and Justin as well as much needed muscle from eldest son Daniel, Wilma,s tub is now mounted to the club rotessorie and I am researching best places to order replacement body parts from (door posts and front floor pans are the primary needs right now - RUST!!!)
Any experience with different vendors, opinions etc..?
And I will be reviewing the extended radius arms thread, is anyone running them yet? I need to build a set for full width axles.
Ok- out to the garage, I need to measure and brace and inspect carefully what I have going on
After the manual labor was done yesterday, we enjoyed the results of my first batch of home brew, everyone seemed to think it is quite tasty!
Last edited by hockeydad4-22 on Mon Feb 01, 2016 11:05 am, edited 1 time in total.
Post by Gunnibronco »
Looks good. Do you already have the axles?
http://denver.craigslist.org/pts/5401415214.html
Oh yeah, I have axles
phyler
CCB Admin
Post by phyler »
I got my floor pans from the Bronco Hut. I liked them. Fit really well. Have door posts, kick panels and rockers from them waiting to go in. Unless someone says that another vendors are that much better, the savings on shipping make them a lot cheaper. I got all of the OEM quality stuff. We'll see how true that is.
OG
hockeydad4-22 wrote:Oh yeah, I have axles
Based on the pics. Looks like you have everything covered. Now I see what you mean about 'black hole'.
I've been reading BH floor pans are the way to go.
JGZ
Post by JGZ »
BH actually supplies a lot of the other vendors with their sheet metal.Plus they use their parts on their restorations every day.Time is money.
Glad to see some movement here! Wilma needs some attention.
Home brew...a white or wheat beer?
I'd buy from BH. There's only a couple of companies making panels, so the vendors are all selling mostly the same stuff. One exception is floor pans, and BH's are supposed to be pretty good. Where they're available, I'd spring for Dynacorn's parts. The core supports I got were at least as good as factory, if not better.
Further de-constructing Wilma this morning.
Pulled the dash pad and dash, who says EB heaters and defroster don't get hot?
Next: measurements and bracing the tub so I can take the doors off and start cutting away "less than desirable" areas of rusted body parts
Post by Rox Crusher »
hockeydad4-22 wrote:Further de-constructing Wilma this morning.
That's interesting it could get that hot
Surely someone was using the defrost as an ash tray?? I've not ridden in one that got that hot! Whew!
Post by akaFrankCastle »
Ignition switch was right below it. And we all know how reliable those things are.
Nope. Somebody welded the windshield frame on when it was replaced (silly POs)
Post by landshark »
Do you need a new defrost duct?
Well she's pissed! I think that like most women, Wilma does not like to be ignored.
So today I measured and braced her tub back into some semblance of an early bronco body. She had bed sides that were 1/4 and 3/4 inch out of plumb, the front door posts and fire wall were leaning well back and had to be pushed forward almost an inch. But now, with the help of a few strategicly placed peices of steel, she is fairly plumb and square.
I have also learned that I will need to do some very serious rust repairs, some I was well aware of, some, I had hoped wouldn't be needed. I have to replace both driver and passenger floors, patch a hole under the seat pan on the passenger side, replace both sides of the front door posts and the rear striker posts on both sides. I am still not sure about the rockers. A previous attempt at restoration has replaced them both, but to call it shoddy workmanship is to give it to much credit. At least the drivers side seems to be pop riveted on, not welded so removal should not be to drastic.
So I ask those of you who have done all the above: What order do I attack he tasks ahead of me?
Of course, pictures tell the story best
More pics
FYI,
The rear tailgate opening is square, and the posts should be plumb. But the posts at the rear (and front) of the door openings tip inward at the top about 1" from the floor to the bedrail. The bedrails should measure 56" +/- apart all the way down the truck. But the bottom of the rear door opening will measure 57"+/- across the floor.
I think I'd door rear door posts first and work forward, setting the door posts & aligning the door to the quarters last.
