Landsharks 69er Bought not built project
Re: Landsharks 69er Bought not built project
Viperwolf1 wrote:Damn. Am I going to be the only one in Moab without any major mods since last year? I feel like I'll be hanging out on the bunny slopes with Shawn.
Thats not true. You did hydroboost. Thats a big change.
Post by Rox Crusher »
I have my pistol in hand but haven't cocked it just yet.
Hoping to pull the trigger early next week.
Even the bunny hills are fun at Moab !
Gears n lockers?
Gregg
Post by Gregg »
Man....I'm sure gonna miss you.
Post by Viperwolf1 »
Right, and more lift in the front, extended the wheelbase and fixed some things. I was just trying to give Shawn a false hope that his Bronco was just as capable as mine. You know, trying to build up his confidence. It might have come out wrong. shrug
He's better off than Jeff was with the locker. And Jeff made everything he tried but that one hill the first day on fins n things.
Gregg
Post by Gregg »
You might not know this... but I'm an expert at living my life with false hope..."Someday, just someday these Bronco guys will respect me"...
Post by landshark »
So guess I should update this thread with my ZF-5 install behind the 400. For full details you can find the thread here:
[url="http://classicbroncos.com/forums/showthread.php?t=228988"]http://classicbroncos.com/forums/showthread.php?t=228988[/url]
But heres the cliff notes :)
Decided I had enough of the NP435 and not only wanted overdrive but something that was a little more drivable. Decided to go with the ZF-5 behind a Ford 400. A few others have had great success with this conversion as the bellhousing on the 460 ZF-5 matches the 351m/400 engine block.
Although the ZF- will bolt up to the engine the input shaft is a bit too long causing the throwout bearing to fall off the input shaft and not allowing good pressure/clutch disk engagement. To solve this problem I had a spacer made that mounts to the front of the flywheel to the crankshaft and spaces everything back to allow good clutch/bearing engagement.
Anyway, here is the play by play...
Length of the 460 version of the zf-5 is 26.25"
I threw it in back of the Bronco and hauled it home
Custom spacer
Pulling out the bag of hammers...
Have everything ready to go to pull the trans and TC however after taking a look I think I will just drop the exhaust to get it out of the way.. anyway quit for the night it was getting cold out there.
Old stuff coming out.. nothing exciting...
ahhh so much better...
ZF-5 and NP435 side by side
Flywheel and spacer fitment.
[IMGhttp://www.almostmadeit.com/g/galleries/140110_ZF-5_Swap/ysune8uz.jpg[/IMG]
Back of the engine - pretty clean!
Spacer on the end of the crankshaft
Flywheel wheel and spacer mounted
ZF-5 in place, clears!
Getting the Dana20 ready for the zf-5 to D20 adpater.
Zf-5 mated to the Dana20 with the adapter
Twin sticks in! I must have mounted them 25 times to get them to fit right, had to bend, heat, cut and more to get them to work - but work beautifully now!
Rear output of the Dana20 - stepped up to a 1350 driveshaft
Working on the clutch linkage - going with a hydro clutch rather than a mechanical.
Clutch reservoir in place.
Clutch linkage - ended up with a threaded piece in the middle to be able to adjust if needed.
Fabbing up my transmission crossmember
Painted!
mounted
Had a bit of an issue finding a starter.. being a bit of a bone head finally tried the stock 400 starter and wouldn't you know.. its works! So found a mini 400/460 starter and got it mounted up.
Still need some final pictures and video, which hopefully I will have here soon but so far its working great, love the ZF-5.. just need to fab up a floor!
Post by landshark »
And.. finally got done with my suspensino fix/upgrade.
Got the Duff arms mounted, frame plated, Diff cover installed, new steering linkage / TRE's and lots of other stuff.
Heres my 7 bay garage where I work on the Bronco - fun times!
I was hoping that I could use the Bilstein 7100's I already had but after some measurements they were just too short. Ordered up some new 14" short body 7100's. I might be able to move the 12" Bilstein to the rear which would be fantastic. I will do some measurements when I remove em.
Anyway - going to re-install the air system, weld up the radius arm mounts, plates I added to re-enforce the frame and get the DOM supports for the upper shock mounts done this week.
Im mounting 12" bilsteins. They're pretty long, and will be up in the wheel well. Not sure if my solution will work of EB width axles, but I can make you some hoops if you want to try it.
Post by landshark »
Justin wrote:Im mounting 12" bilsteins. They're pretty long, and will be up in the wheel well. Not sure if my solution will work of EB width axles, but I can make you some hoops if you want to try it.
I appreciate it.. i have the duff hoops and already ordered the shocks. I think I will be ok - besides the extra cash iam spending on the shocks. I think I might be able to move the old ones to the rear and then sell the 5150's I currently have and recoup some of my money.
With the axle just hanging off the coils I was already maxed out on the shocks at 26.5" (If I remember correctly) so the new ones should be perfect for my setup once I add the 2x2 tube to limit up travel.
Gotcha, that should make a difference. Sounds like a good plan.
Looks good Chris. But where are the flex pix?
Post by landshark »
Waiting on shocks and still need to weld stuff up ;)
Post by landshark »
Fabbing up my tunnel cover to cover up the holes cut into the floor board for the ZF-5 and transfer case.
got to use my shears! first time in 5 years...
next up is to cut out the shift areas and make the bends. Next I will take it to Line-x to see if they will shoot it to match the floor in the bronco..
Post by landshark »
got the floor patch in with the shift boots, works pretty good but will be taking the floor piece into line x to match the floor and help the heat and noise.
On the lookout for a bigger shift boot, will have to keep my eye out at the boneyard
Sweet, that looks great! Too bad it needs Line-X, it's kinda pretty.
Post by landshark »
Justin wrote:Sweet, that looks great! Too bad it needs Line-X, it's kinda pretty.
thanks, i just want to cut down on the road noise and heat... plus its kind of a non-slip and easy to clean
Post by landshark »
Got the tunnel cover done.. like the way it turned out!
I might paint the screws eventually but kind of like the "rivet" look
It will look like the rest of the floor very soon :)
Yeah, good thing it's going to dusty Moab to make it match! Looks great. Nice piece there!
Post by landshark »
Opps.. too much fun in Moab ;)
Seems like the ZF changed the angle of the engine just enough to grab my fan shroud and eat the radiator..
Luck was with me as I found used radiator out of a 60s or 70s AMC (Maybe from a jeep wagoneer or something?) in the parts pile of a 4x4 shop in town, only radiator they had and unbelievable I got it to fit - bonus that the bronco mounts even worked. Made the repair on the trail and continued on - Matter of fact I ran Poison spider the next day...
I will have to take a picture next week when I pull it to put a new one in but its been patched twice (2 holes in it), it will be going on the garage wall as a "spare" :)
I will have to see if others have pictures of the actual carnage as someone took the fan to use as art...
anyway just ordered a new replacement from Summit and will be running a smaller spacer and clutch fan from now on...
D&D72
Post by D&D72 »
Tell us that happened on carnage!
Post by landshark »
just the fan and radiator.. ordered a new radiator today from Summit should be here by Friday :)
Post by landshark »
So a quick update. Turned out the radiator was from Summit and cost $159 - shipped.. so replaced it with the exact same one.
While i had it out I took advantage of the extra space did some belt tightening, fixed my power steering lines running them slightly better and then installed a clutch fan that I have had hanging on the wall for about a year thanks to Zoso. So far so good, now I have to make a fan shroud which shouldn't' be too hard.
Heres the radiator I used - Jeremy and I found it besides a 4x4 shop in Moab.. its out of a 87 CJ-7
New radiator in...
*cool* (tongue in cheek)
Post by Kinder »
On Track has some DIY shroud pieces on the shelf, I didn't check prices, but nice to have a local source.
I didn't know that. What pieces do they have? I've been contemplating making my own.
Post by landshark »
Cool will run over there and check them out. Was going to pick up some aluminum and have it tig welded
Post by Kinder »
I think they have most of the pieces for a simple shroud.
Post by landshark »
kinder wrote:I think they have most of the pieces for a simple shroud.
Iam going to head over there at lunch thanks.
