I have two bolts that snapped supporting my transmission cross member. I've tried penetration oil and an extraction bit and also torching it out. Neither worked. I got the bolt free just from drilling through. But now I have no threads and a bigger hole. Figured I'd seek help before I really screw it up.
Anyone out there who knows how to do this?
Anyone in Aurora area know how to die/tap a new thread?
- laffycaffi
- Eck
Re: Anyone in Aurora area know how to die/tap a new thread?
Go get a tap set from Harbor Freight and you would tap it by hand slowly and careful to keep it straight. ItΓÇÖs not complicated at all.
- cpldavis37
If you can weld a nut to the bolt you can just turn it out. Its the easiest way I have found to get a snapped bolt out.
TJ
F. Scott Fitzgerald
F. Scott Fitzgerald
- laffycaffi
Got it. Thanks B.O.B. for letting me borrow your kit. Easier than expected.
Sent from my SM-N950U using Tapatalk
