Should correspond to MY 1974 and 1975 as far as I know. 10" brakes / 3/8in bolt holes in flanges / "torino" end pattern I believe
Planning to build a new rearend this winter. Expect to buy a fresh housing from a vendor but figured might as well at least try to find a used one first.
WTB medium duty lg bearing housing (EB width)
OldBalls
- Viperwolf1
Re: WTB medium bearing housing (EB width)
Medium duty with big bearings and 10" brakes?
pgilbeau
I have a '74-75 early Bronco housing and a new Yukon 31 spline axle shaft kit I have been trying to sell. The housing has been hot tanked to get all the grease off. This is the kit I have: https://www.randysworldwide.com/product ... onco-4-31/
OldBalls
Yes that's correct medium duty big bearing 10" brakes 3/8" bolt holes on flanges. I'll see if I can edit the post to clarify.
Will PM about the housing. As it happens I already have that same axleshaft kit. Thx guys.
OldBalls
Re: WTB medium duty lg bearing housing (EB width)
Looks like the housing is sourced. Thanks Phil!
OldBalls
WTB 4.88 gear set 9"
Looking for quality parts in decent shape... plan to drive this truck a lot
