Anyone know what size the set screw is on the wiper switch?
Also, mine when the key is in the on position makes a noise like a spring is being plucked. Assuming it's bad and that's why my wipers don't work. The switch is loose so it could be a bad ground there as well but that goes back to my first question. :)
Wiper switch
- phyler
- CCB Admin
Wiper switch
OG
OG
- phyler
- CCB Admin
Re: Wiper switch
Figured it out. It's a 5/64th. Had to clean it out a bit for out to fit.
Then was able to tighten the nut and adjust everything and I got my wipers back.
OG
OG
