I installed a '79 tilt column in my '68 and all of my lights work as they are intended except for the Passenger rear tail light?
It works when you turn the lights ON for night driving,
Doesn't work when you brake
Doesn't work when you put the Right Turn Signal on?
It has a new New Brake switch above the brake pedal as well.
Any suggestions?
cut wire? ground issue?
The 2 little brothers got to drive it from Eaton to Loveland and they were in Heaven!!!
No Passenger brake light?
- mickphatmac
- Viperwolf1
Re: No Passenger brake light?
Bad ground.
- mickphatmac
ThankYou Phil, when I opened it up the rear passenger tail light, the wires were garbage and all cut up so I took an extra tail light bucket I had sitting around, replaced it with that, it had the factory plug-ins on the back and IΓÇÖm proud to say all of my lights work on the ΓÇÿ68!!!
... Even my dome light!!! (Fancy!)
