Hydroboost seal
Hydroboost seal
Post by Eck »
I need the main seal for the main piston. I have ordered a few but USPS has it stuck somewhere in their system.
Does anyone have one local that I could buy or use and then replace when mine come in?
Long shot IΓÇÖm sure.
BroncoRaider
Re: Hydroboost seal
Post by BroncoRaider »
Ive got a rebuild kit. If itΓÇÖs in there, we can make that work.
Re: Hydroboost seal
Post by Eck »
BroncoRaider wrote:Ive got a rebuild kit. If itΓÇÖs in there, we can make that work.
That is awesome-- it should be in there but it is the larger round seal in this picture. If you are around later this afternoon ( after 4:30-- I could swing by and grab it)! Thanks!
kbank6
Re: Hydroboost seal
Post by kbank6 »
if it's not in the kit you could try Rocket Seals in Den.
Re: Hydroboost seal
Post by Eck »
kbank6 wrote:if it's not in the kit you could try Rocket Seals in Den.
Tim had me covered but thanks for the local recommendation. I was hoping to have it all back together and tested today but I snapped an AN fitting tightening everything up so now I wait for the mail system once again.
Re: Hydroboost seal
Post by landshark »
What an fitting do you need? I might have it
Re: Hydroboost seal
Post by Eck »
landshark wrote:What an fitting do you need? I might have it
The 5/16 24 o ring to 6 AN for the hydroboost low pressure. I believe itΓÇÖs also called the spittier. It is the port that normally has the hose barb fitting.
Re: Hydroboost seal
Chris, where did you source your fitting and was it decent quality?
Hydroboost seal
Post by landshark »
Justin wrote:Chris, where did you source your fitting and was it decent quality?
I did not have one. Last time I bought them I think it was off ebay
Re: Hydroboost seal
Post by Eck »
labwork 6 an x 5/16-24 o Ring hydroboost spittier/Return Port https://www.amazon.com/dp/B07TWJVX7C/re ... UTF8&psc=1
This is what I just got. Seems like good enough quality- just donΓÇÖt over tighten this fitting since it is so small and is only low pressure anyways.
Re: Hydroboost seal
Cool, thanks. I'll order that labwork one. Hydratech sells on, but its 2x the price and they've got warnings all over their site to only torque to 10 ft/lbs and hold it while you attach a hose.
