There's a baffle inside there prevents me from getting to it that way. I thought it just pulled off as well. It is super stuck but rotates freely.B.O.B. wrote:I usually just pull them out. Maybe push it out from the inside? If itΓÇÖs old it might by stuck on the rubber grommet.
That's what I will do. I just wanted to make sure I wasn't doing something dumb.Justin wrote:If you can't break it out, I'd score it with an exacto knife or pneumatic body saw. Heck, a hacksaw blade would probably work too.
Yeah. Now to move on to rebuilding the carb. Broke that pcv breather taking the valve covers off to check the valves as I've gone to about 8mpg. Trying to get it back to the 11-12 I used to get.Justin wrote:Success! I like it.
Here are plugs from the 5 and 6 cylinders. The others are similar.Digger wrote:What do the plugs look like?
